5 members (Graham, G4FUJ, Montegue, James B W, jejemek, Pittsartist), 232 guests, and 59 robots.
+8Rich 94
Posts837,273
#758393 17/10/22 07:33 AM
Can anyone help locate a replacement grommet for a Roadster 2019 washer bottle please, mine has swollen & split so clearly doesn’t like my water.......
80’s J Deere Tractors, Morgan Roadster & 1929 Scott Flying Squirrel
Likely a generic item. Measure inside and outside dimensions then search for similar on eBay or Amazon.
You could make your own. I bought some round section O-ring material for a job a while back. Cut to length for the circumference you need and superglue to connect the ends. I have a box of O-rings but none fitted so bought the right diameter( thickness). If I remember correctly it was sold by the metre and not expensive. I’ll see if I can find details. A google search is another way to find some.
From memory they are quite wide in the recess to fit the thick plastic bottle, mine split on my 2018 Roadster & the factory kindly sent a full bottle (under warranty) because it's not listed as separate part
You could try Melvyn Rutter, he's good for these daft bits others don't stock
Just for future reference it’s an original Mini grommet, thank you for your help chaps.
Nigel, this one ?
https://www.minispares.com/product/Classic/Grilles_Brightwork/Wipers/Bottles_pumps/BAU2043A.aspx?160503&ReturnUrl=/search/classic/grommet.aspx|Back%20to%20search
if correct, that's a great find thumbs
As I was passing Mini Sport the other day I picked up this, fyi you can't buy direct from Xpart but both Mini Sport & Mini Spares keep them in stock, just ask for the later SPi & MPi models style of washer bottle
Those are indeed the ones, quite a common part when you search.
X
X
2018 plus4 (sports green)
