2 members (Julian BB, Marmota),
375
40
Posts837,276
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
So, what is the collective wisdom on the proper torque setting for this crank nut? ![[Linked Image]](https://www.tm-img.com/images/2022/11/25/IMG_0969.jpeg) Phil B says about 440 lbft for a full sized nut is correct. FWIW when he refitted mine a few months ago he used a flat washer and loctite but no star washer
Red Leader
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Red Leader, that is a heck of a lot of torque! Thank you.
I wonder how you can get that much torque on that nut? What kink of tool?
An approx 3ft lever and a 150 lb person on the end...........
Red Leader
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
Can't remember what torque I tightened my one to, but it was definitely tight with a capital "F"
Posts: 1,981 Likes: 103
Posts: 1,981 Likes: 103 |
An approx 3ft lever and a 150 lb person on the end........... Or have Lin Guoer sort it for you https://youtu.be/INcLC9AYH60?t=256 (ignore the ads) ![[Linked Image]](https://www.tm-img.com/images/2022/11/26/No-spanner.png)
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
Posts: 786 Likes: 18
Posts: 786 Likes: 18 |
440 lb ft doesn't seem like the right torque to me, t seems to me that MMC says 24 mkg, for my 3w is 28 mkg.
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
Morgan state 170 lbs/ft, Phil Bleazey uses 440 lbs/ft, which I believe is based on the specified torque for a 7/8 UNF nut. Note though Morgan only use a half nut whereas Phil uses a full nut.
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
Morgan state 170 lbs/ft, Phil Bleazey uses 440 lbs/ft, which I believe is based on the specified torque for a 7/8 UNF nut. Note though Morgan only use a half nut whereas Phil uses a full nut. seems like Morgan quality is always just a half nut
I bet she would be a dab hand with the 3 wheeler, 2nd hand head gasket and not a torque wrench in sight, lush.
