0 members (), 308 guests, and 46 robots.
+8Rich 93
Posts837,277
Page 6 of 10 1 2 4 5 6 7 8 9 10
So, what is the collective wisdom on the proper torque setting for this crank nut?
Phil B says about 440 lbft for a full sized nut is correct.
FWIW when he refitted mine a few months ago he used a flat washer and loctite but no star washer
Red Leader drive
Red Leader, that is a heck of a lot of torque! Thank you.
I wonder how you can get that much torque on that nut? What kink of tool?
An approx 3ft lever and a 150 lb person on the end...........
Red Leader drive
FT!
Can't remember what torque I tightened my one to, but it was definitely tight with a capital "F"
Or have Lin Guoer sort it for you https://youtu.be/INcLC9AYH60?t=256 (ignore the ads)
440 lb ft doesn't seem like the right torque to me, t seems to me that MMC says 24 mkg, for my 3w is 28 mkg.
Morgan state 170 lbs/ft, Phil Bleazey uses 440 lbs/ft, which I believe is based on the specified torque for a 7/8 UNF nut. Note though Morgan only use a half nut whereas Phil uses a full nut.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
seems like Morgan quality is always just a half nut pantsdown
Rodger
2004 Plus 8 (wife's)
I bet she would be a dab hand with the 3 wheeler, 2nd hand head gasket and not a torque wrench in sight, lush.
