8 members (TBM, IcePack, Graham, G4FUJ, Montegue, JohnHarris, Image, RichardV6, bmgermany), 390 guests, and 47 robots.
+8Rich 92
Posts837,279
Page 14 of 17 1 2 12 13 14 15 16 17
Derek596 #767343 20/01/23 06:33 PM
Sorry I'm only today come to look at the brakes more closelyIn my PlusFour model year 2022 it is a single-piston brake.
The manufacturer can not be identified
Clemens
PlusFour Red Baron MY 2022
Derek596 #767346 20/01/23 06:51 PM
And the sliding mechanism isn’t protected by a rubber covering as most cars are, they’re open to the elements and if not used often enough they will seize up.
Heron Grey Plus Four 2021
Previous:-
Connaught Green 4/4 1988
Black Plus 8 1998
Derek596 #767381 21/01/23 01:47 PM
TBM Online Content
Is that not a dual piston? One piston either side of the disc.
TBM #767382 21/01/23 01:53 PM
No signs of a hydraulic line connecting across to the other side?
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Deejay #767384 21/01/23 02:00 PM
TBM Online Content
It'll travel through the body of the caliper - with a single pot, the caliper usually slides in a carrier, on dual pots the pads slide on pins.
Derek596 #767385 21/01/23 02:12 PM
TBM Online Content
My 1972 had dual pots with no connecting line.
Same with the uprated 4 pots, no line
Derek596 #767389 21/01/23 03:01 PM
It's not easy to photograph this... played with the brightness again.
I only see a piston on the inner side where the vent is placed.
Clemens
Derek596 #767390 21/01/23 03:24 PM
If you take the pads out you will eliminate the guess work and know for sure, looks easy enough.
Previous Mog Plus 4 Fiat Twin Cam.
Plus Six
Derek596 #767393 21/01/23 03:40 PM
As I’ve said before, it’s a single piston.
Previous:-
Black Plus 8 1998
Derek596 #767395 21/01/23 03:51 PM
Thanks for posting the pic Clemens.
Unfortunately the mechanism that allows the calliper to slide back and forth as the brakes are applied and released is not obvious from the angle you took the pic from.
