2 members (Julian BB, Marmota),
375
40
Posts837,276
Posts: 1,163 Likes: 354
Posts: 1,163 Likes: 354 |
Sorry I'm only today come to look at the brakes more closelyIn my PlusFour model year 2022 it is a single-piston brake. The manufacturer can not be identified ![[Linked Image]](https://tm-img.com/images/2023/01/20/3D1D3BE0-7BA7-4AB3-A88A-F3E200DBF217.jpeg) ![[Linked Image]](https://tm-img.com/images/2023/01/20/3688CE9F-C30C-4CD5-A88A-5987B75C70DD.jpeg)
Clemens
PlusFour Red Baron MY 2022
Posts: 82 Likes: 1
Posts: 82 Likes: 1 |
And the sliding mechanism isn’t protected by a rubber covering as most cars are, they’re open to the elements and if not used often enough they will seize up.
Heron Grey Plus Four 2021
Previous:- Connaught Green 4/4 1988 Black Plus 8 1998
Posts: 6,666 Likes: 433
Posts: 6,666 Likes: 433 |
Is that not a dual piston? One piston either side of the disc.
Posts: 2,085 Likes: 69
Posts: 2,085 Likes: 69 |
Is that not a dual piston? One piston either side of the disc. No signs of a hydraulic line connecting across to the other side?
Is that not a dual piston? One piston either side of the disc. No signs of a hydraulic line connecting across to the other side? It'll travel through the body of the caliper - with a single pot, the caliper usually slides in a carrier, on dual pots the pads slide on pins.
My 1972 had dual pots with no connecting line. ![[Linked Image]](https://www.tm-img.com/images/2022/06/06/282017640_10166117052040034_6595677168008678428_n.md.jpg) Same with the uprated 4 pots, no line ![[Linked Image]](https://www.tm-img.com/images/2020/04/26/v1SQyPVN8H6iekaqHxp83z2ykiRv4ry6a-FDNQ-X6Lw2E7y6RbF_nvUSnGQaA6f4qKOVgFt8Ay4U_bE6rUGMri_Tz5QuQVXZMQjqxe_8zUnLORlNXPpjIli4LpNBLSb32vuIS2cyvEZ5ay9ad36KKzUbbHOpmNbjNZ0fuTTHGRdEwv1onnmebujlKGs-bF_1lB0fBV99.jpg)
It's not easy to photograph this... played with the brightness again. I only see a piston on the inner side where the vent is placed. ![[Linked Image]](https://tm-img.com/images/2023/01/21/9256808C-E559-4C43-BEDB-72F51ED6518B.jpeg)
Clemens
Posts: 206 Likes: 15
Posts: 206 Likes: 15 |
If you take the pads out you will eliminate the guess work and know for sure, looks easy enough.
Previous Mog Plus 4 Fiat Twin Cam. Plus Six
Posts: 82 Likes: 1
As I’ve said before, it’s a single piston.
Posts: 5,432 Likes: 466
Posts: 5,432 Likes: 466 |
Thanks for posting the pic Clemens.
Unfortunately the mechanism that allows the calliper to slide back and forth as the brakes are applied and released is not obvious from the angle you took the pic from.
