6 members (Doug J, Peterkul, TeddyAds, Zach, Graham, G4FUJ, Liam1961),
315
48
Topics49,841
Posts837,316
Posts: 318 Likes: 5
Posts: 318 Likes: 5 |
My '74 4/4 has developed a crack in the water pump housing (maybe due to the cold weather but the antifreeze was good down to -20C). Do I need one specifically for the 1600 GT engine or will any 711M block pump do?
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
I think all 711 would be the. Same.
Posts: 809 Likes: 59
Posts: 809 Likes: 59 |
I just got a new one from Burton for my 711M
Posts: 28,891 Likes: 350
Posts: 28,891 Likes: 350 |
I think Ray is correct, but you could double check with BHM or New Elms
Posts: 6,667 Likes: 433
Posts: 6,667 Likes: 433 |
Yep, replaced mine last year and it was a standard Ford part I got from Burton Power.
It arrived without the the heater hose 'take off', but you can either take the old one of the old waterpump or buy a new one. I replaced mine with a straight, rather than a 90 degree one as I fitted a bleed valve in the heater hose at the highest point to remove any air from the system.
Posts: 52 Likes: 2
Posts: 52 Likes: 2 |
Any 711 crossflow will do, I fitted a new one to my crossflow last year because it started to squeal ( probably due to standing over winter) £27.99 delivered from sparesworlddirect
Mark
1979 4/4 crossflow engine by Colin Musgrove, twin 40’s
Good move on the bleed point Phil!
Good move on the bleed point Phil!  Cheers. It has made it so much easier to remove any air from the system. ![[Linked Image]](https://www.tm-img.com/images/2023/02/04/bleed.md.jpeg)
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
Good move on the bleed point Phil!  Used on my Delorean and other vehicles. It's been a lifesaver.....
Posts: 1,616 Likes: 142
Posts: 1,616 Likes: 142 |
Any crossflow pump but not a pre crossflow pump.
Pre crossflow pumps are slightly wider
Arwyn
