8 members (vincentvg, jbk, TBM, Clipper, nick w, Barkbark, DJC, Ritchie B), 316 guests, and 17 robots.
+8Rich 92
Topics49,838
Posts837,294
#768497 03/02/23 12:12 PM
My '74 4/4 has developed a crack in the water pump housing (maybe due to the cold weather but the antifreeze was good down to -20C). Do I need one specifically for the 1600 GT engine or will any 711M block pump do?
Ray Offline
I think all 711 would be the. Same.
I just got a new one from Burton for my 711M
73 4/4 "Henry A"
53 +4 Flat Rad "Pug"
84 Citoen 2CV Spec "BeBe"
60 MGA
https://morgan34.org/
I think Ray is correct, but you could double check with BHM or New Elms smile
TBM Online Content
Yep, replaced mine last year and it was a standard Ford part I got from Burton Power.
It arrived without the the heater hose 'take off', but you can either take the old one of the old waterpump or buy a new one. I replaced mine with a straight, rather than a 90 degree one as I fitted a bleed valve in the heater hose at the highest point to remove any air from the system.
Any 711 crossflow will do, I fitted a new one to my crossflow last year because it started to squeal ( probably due to standing over winter)
£27.99 delivered from sparesworlddirect
Mark
1979 4/4 crossflow engine by Colin Musgrove, twin 40’s
Good move on the bleed point Phil! thumbs
TBM Online Content
Cheers. It has made it so much easier to remove any air from the system.
Used on my Delorean and other vehicles. It's been a lifesaver.....
Any crossflow pump but not a pre crossflow pump.
Pre crossflow pumps are slightly wider
Arwyn
