Topics49,837
Posts837,288
Posts: 101 Likes: 5
Posts: 101 Likes: 5 |
That's interesting as it (yet again) acknowledges a known problem by the factory. In which case, it ought to be properly sorted out via a recall or attended to at the next service.
Andy 2022 Plus Four / San Marino Blue
Posts: 48 Likes: 1
Posts: 48 Likes: 1 |
Thanks Cooperman. Cap not securing after fill up. Remembered this thread and bought some WD Silicone Lubricant. Wow, a couple of sprays, rotated several times, retried and working better than when first bought. A simple fix. Cheers Ian
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
Posts: 31 Likes: 11
Posts: 31 Likes: 11 |
I was in touch with Newton Equipment who manufacture the PlusFour CX fuel caps. They simply suggest loosening (or tightening) the nut on the back of the filler cap a quarter-turn - if it tends to jam (or is too loose). The nut is visible in the attached photo. ![[Linked Image]](https://i.ibb.co/PNKXm79/IMG-7235.jpg)
Posts: 1,163 Likes: 354
Posts: 1,163 Likes: 354 |
Thanks for posting this the information 👍
Clemens
PlusFour Red Baron MY 2022
Posts: 208 Likes: 7
Posts: 208 Likes: 7 |
I just did it. It works significantly better.
Posts: 238 Likes: 3
Posts: 238 Likes: 3 |
My turn to encounter this problem. Did the Williams track day at Castle Combe and got the fuel light part way through the afternoon. Drove to local petrol station. Spent the next 10 mins failing to open the filler cap so gave up and headed home early  luckily with enough fuel to make it home. Spent another 15 mins fiddling with it this morning in the garage and finally managed to get it open. I could get the top to turn but the lower plastic part was not aligning properly so keeps catching. Have greased it but still catching. Will try tightening the nut slightly to see if that keeps alignment better. Ps. I noticed the image above shows the cap without the retaining cable. Have others removed the cable? It seems to be more of a hindrance to the locking mechanism than a help in keeping the cap attached when open for fuelling.
David
MY22 Plus Four, Alligator (AML Racing) Green ! 😍
Simply "shake" the lid when opening ... this always helps me to open the tank lid David
Clemens
Posts: 31 Likes: 11
Yes, my retaining cable had actually sheared off before I took the photo above. As you say, I think the cable is a bit of a hinderance anyway.
Since adjusting the nut (per the above post) - I’ve had no problems with the locking version of the cap.
Posts: 1,873 Likes: 174
Posts: 1,873 Likes: 174 |
My turn to encounter this problem. Did the Williams track day at Castle Combe and got the fuel light part way through the afternoon. Drove to local petrol station. Spent the next 10 mins failing to open the filler cap so gave up and headed home early  luckily with enough fuel to make it home. Spent another 15 mins fiddling with it this morning in the garage and finally managed to get it open. I could get the top to turn but the lower plastic part was not aligning properly so keeps catching. Have greased it but still catching. Will try tightening the nut slightly to see if that keeps alignment better. Ps. I noticed the image above shows the cap without the retaining cable. Have others removed the cable? It seems to be more of a hindrance to the locking mechanism than a help in keeping the cap attached when open for fuelling. I had this problem when heading to Denmark with an empty fuel tank. The dutch AA homeservice came to open it, instructed by the dealer. After one tankstop before Hamburg we had again problems, MorganPark in Hamburg solved the problem (which is very wel known...) by abraising some material from the material inside the filler cap. Now it has more "room" and everything goes fine. Your dealer can deal with it! Good luck! ![[Linked Image]](https://tm-img.com/images/2023/08/20/IMG_4143.jpeg)
Ruut Bianchi Morgan PlusFour 2023 Bentley Midnight Emerald Morgan 4/4 4-seater 1990 Royal Ivory
