1 members (Montegue), 259 guests, and 51 robots.
+8Rich 93
Posts837,277
Page 4 of 15 1 2 3 4 5 6 14 15
Rog #776405 03/05/23 07:28 PM
For those that don't have fancy printers, legend sheets are readily available (may be an MOT fail if switches not labeled correctly)
https://www.carbuilder.com/uk/self-adhesive-switch-legend-sheet-black-text
Rog Offline OP
Originally Posted by bobar
What a terrific job.
My 2012 plus4 PCB failure caused one light to remain illuminated. The only solution offered was complete replacement of the board at significant cost. The malfunction appeared to have been caused by water ingress.
My solution of sticking electrical tape over the light paused the irritation, but pales somewhat in seeing your elegant work.
Morgan should be beating a path to your door with a consultancy proposal.
thumbs
There’s an old TM image of a pcb that suffered from water damage or a short in the indicators. Can’t remember precisely but it burnt out some of the tracking which is shown here repaired. Quite an expensive fuse…
Here a foto from the labels I made with a labelprinter - not the best solution but it works...
That’s a very nice dash indeed Bernt. Do you still have your pcb somewher behind there?
Roger
Rog #776410 03/05/23 08:05 PM
Roger
Thank you, but the dashboard It is only a MK design - but I like it too..
I am happy that I decided to swapp my black switch levers for the ivory ones.
Rog #776445 04/05/23 09:06 AM
Wow Roger what a lovely job as always.
Looks very tidy and a lot more straight forward for future maintenance. Well done that man.
Out of interest what is the name of the enclosure that you have used to house your electronic masterpiece?
I have been looking for that very thing for another project for some time now but just can't find them.
Well done again and keep up these interesting posts.
Rob....
Why is there only one monopolies commission??
Rob B.
Rog #776483 04/05/23 04:37 PM
Outstanding work Roger notworthy
BLUE+4 #776501 04/05/23 08:49 PM
Rog Offline OP
Thanks Dave thumbs
Rob....
Thanks Rob, sorry but the enclosure is a 3d printed home brew job that I did just for this job frown
Roger
Rog #776509 04/05/23 09:46 PM
Anyone who wants a failed S2 pcb to play with please pm me.
Rog #776529 05/05/23 07:49 AM
For an enclosure you could try a waterproof fly box and take out the inside..
https://www.ebay.co.uk/itm/23455203...r=&widget_ver=artemis&media=COPY
Ok maybe not an orange one but you get the idea
Rog #776530 05/05/23 07:50 AM
For my understand why did they move to a PCB in the first place, was it from 2003? My 1996 car just has simple switches and fuses.
Rog #776541 05/05/23 10:56 AM
Rog Offline OP
Good question! I don’t know the reason why a semiconductor packed circuit board was used on these pre BCU cars. I appear to have gotten away with just switches wires and regular relays, time will tell...There are two heavy duty diodes in my concoction but that’s an unnecessary luxury simply because I couldn’t find a double gang toggle for the hazards with a led to match the others. The pcb even has a pic micro that appears to be there to drive the indicators, a £4 Landy flasher seems to work fine too. The only reason I can speculate why it might possibly have been used was to reduce the car’s initial build time, thus keeping production costs down?
Roger
