8 members (John Winn, Malcolm T, TBM, vincentvg, gmcn, +8Rich, DaveW, Alistair),
294
63
Topics49,871
Posts837,680
Posts: 197 Likes: 1
Posts: 197 Likes: 1 |
Gentlemen,
Mulberry Fabrication can now supply an alloy header tank to replace the ‘plastic jobby’ that is OEM.
It does require fitting - 8 & 6mm drills, centre punch & 13mm & 8mm spanner & socket.
It is fitted to the centre bracket on the Mulberry tie rod (comes with Mulberry radiator) and a new bracket drivers side front catch mounting. Both brackets on M8 rubber mounts - looks better than the Ford coolant tank and securely mounted.
I would post a picture but beyond my IT skills
Posts: 8,684 Likes: 493
Posts: 8,684 Likes: 493 |
Would really like to see a photo of that installed
Posts: 27,817 Likes: 749
Posts: 27,817 Likes: 749 |
Bumpy Will pm you my email. If you send me the photos I'll post them
Posts: 197 Likes: 1
Here we go that does look smart. I like the way it doesn't rub on the engine What do they cost? ![[Linked Image]](https://www.tm-img.com/images/2023/11/08/IMG_9994.jpeg) ![[Linked Image]](https://www.tm-img.com/images/2023/11/08/IMG_9991.jpeg)
Posts: 8,684 Likes: 413
Posts: 8,684 Likes: 413 |
Sorry to say but a big negative for me would be not easily seeing coolant level.
True Richard, but opening the cap when cold is not a lot of effort
1 member likes this:
Graham, G4FUJ |
Posts: 2,116 Likes: 68
Posts: 2,116 Likes: 68 |
Sorry to say but a big negative for me would be not easily seeing coolant level. Perhaps a dipstick helps like used on the fuel tank on the "Trabbi"? ![[Linked Image]](https://tm-img.com/images/2023/11/08/Trabi-Tankanzeige.jpeg) Or two small pipe bends with a piece of hose?
+8Rich |
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
The CX cars have ali tanks with no clear level check “windows” or pipes. Not a problem. When cold (really the only time to check) I just look down inside. Dark? Use a torch. I find my middle finger acts as a dipstick. The tip matches the level sticker on the outside. I also have cardboard on the floor under the car to show any leaks ( oil or coolant). At the moment I am doing VERY regular checks due to the early cars’ coolant/rad leak issues. No losses so far after 4.5k miles. The oil level check is “different” with no dipstick ! Hot engine and running then press a button. The result shows up on the small screen. Colour of the display indicates level and how much to add. Currently green meaning full. Been standard on BMW for several years. Tech eh!
I totally agree that there are relatively easy ways of checking coolant level but absolutely nothing beats being able to see level the instant you lift one or other bonnet, whether intending to check or not.
