10 members (Willowgreen320, stefan s, Nick55, deano, Dek, Gramrugby, ajsms999, 2949olivier, MJF, BLUE+4),
253
121
Topics49,871
Posts837,677
Posts: 8,684 Likes: 413
Posts: 8,684 Likes: 413 |
The CX cars have ali tanks with no clear level check “windows” or pipes. Not a problem. When cold (really the only time to check) I just look down inside. Dark? Use a torch. I find my middle finger acts as a dipstick. The tip matches the level sticker on the outside. I also have cardboard on the floor under the car to show any leaks ( oil or coolant). At the moment I am doing VERY regular checks due to the early cars’ coolant/rad leak issues. No losses so far after 4.5k miles. The oil level check is “different” with no dipstick ! Hot engine and running then press a button. The result shows up on the small screen. Colour of the display indicates level and how much to add. Currently green meaning full. Been standard on BMW for several years. Tech eh! Same for our diesel BMW B47 engined Mini which has never shown in over 47,000 miles other than oil level OK on display, so no top ups between changes. After owning the car for several years though I did find a not very obvious engine oil dipstick. I wonder therefore if there is a hidden one on your B48 petrol engine.
Posts: 8,684 Likes: 493
Posts: 8,684 Likes: 493 |
I totally agree that there are relatively easy ways of checking coolant level but absolutely nothing beats being able to see level the instant you lift one or other bonnet, whether intending to check or not. I'm with you on that Richard, plus my QA ocd would have to 'snag' the lumpy welds (not as neat as SiFab)
Posts: 37,436 Likes: 982
Posts: 37,436 Likes: 982 |
Compared to the one's that Jays and Craig had fitted to theirs this looks rough as you like also had a visual level gauge, I believe they sourced from Henry so possibly a Simon product ? ![[Linked Image]](http://tm-img.com/images/2023/11/09/ht.jpeg) This looks like Craig's car in the Williams induction kit advert.
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Compared to the one's that Jays and Craig had fitted to theirs this looks rough as you like also had a visual level gauge, I believe they sourced from Henry so possibly a Simon product ? ![[Linked Image]](http://tm-img.com/images/2023/11/09/ht.jpeg) This looks like Craig's car in the Williams induction kit advert. Yes that’s my old 4/4 I sold, I bought the header tank from Williams Automobiles ![[Linked Image]](https://tm-img.com/images/2022/03/12/8E35173F-D02A-4012-97CE-4A251A21A82A.jpg)
Craig Jezz
Better pic here ![[Linked Image]](https://tm-img.com/images/2021/10/21/B6769E5E-47AE-4681-87C2-9D733796B93C.jpg)
Craig Jezz
That Williams one looks very nicely done and incorporates a sight glass
There used to be an Ad in Mog Mag in it's early days, someone offering Mog header tanks and his photos looked good, can't find it though
