1 members (ChrisConvertible), 212 guests, and 32 robots.
+8Rich 90
Topics49,841
Posts837,323
Christoph
Mark+4 Offline OP
I added a band to the Valve lever see the other thread for overall results, I believe its working as best it can in a Morgan.
https://www.talkmorgan.com/ubbthreads.php/topics/795864#Post795864
Mark
2015 +4 Ferrari Le Mans Blue
Originally Posted by John V6
There are lectric ones on ebay with 4 way control here. Not sure about the spiogt diameter required though
Looks interesting for me, but only if it works as an on/off valve.
There are only two pins to the solenoid/motor Peter so looks like it could only be such. The low price seems to confirm wink
Originally Posted by Mark+4
.......I had a really good look at all the pics of the Bypass identified by John, I don't want to stifle any ideas and thanks for bothering to search, but I don't think its a 4 way. To me it looks like the Valve sits at the junction of 3 ports with one going to a T, which makes it very similar to the Taxi one in concept. It's really hard to tell when they don't provide enough detail, not even the ID diameter of the ports.
Given it has four hose unions I don't see how you can conclude it's a three port valve Mark thinking
Standard heater hose is 16mm (⅝") i/d and this is a heater valve so no worries there.
Mark+4 Offline OP
I just used my eyes, could be wrong.
Mark
Mark+4 Offline OP
Update.
I eventually finished this project and fitted a Bowden Choke Cable so the valve can be opened/closed without having to get my hand through to the little lever.
I mounted one end on top of the heater matrix, it was going under the leading edge but it made getting the lid of the fuse box a bit tricky.
I had to make a bracket for the other end and crimped an electrical connector to the end to go over end of the lever.
Tested and works ok at the moment.
I considered trying to get the cable through to the cabin and even attached to the existing heater control knob but both were too difficult so went for the easiest option.
Regards
Mark
Neat solution Mark which hopefully acheived the desired results thumbs
Assuming you employed a bypass valve similar in action to one above, I cannot see how there would be any flow through heater core from any small leak via butterfly valve when in bypass mode, reference comments made earlier in this thread. This since same leakage would be presented to each end of core, cancelling any flow thinking
Black Rat
Black Rat
I need one of those so my A/C works.
Keith
2013 narrow bodied + 4 Ruby.
