3 members (Hamwich, gomog, JohnHarris), 380 guests, and 83 robots.
Topics49,848
Posts837,406
DazMog, The Impaler, tlchzj79
TBM Offline
As said above I'd check the indicator relay (different to hazard) and the hazard switch. It's fairly easy to remove and open up to clean the contacts. On mine the feed for the indicators goes through the hazard switch.
I believe the hazard switch is this one if it proves to be the cause of issue. Click for source.
Given the price just as easy to replace keeping old one for future repair and spare.
I had exactly this problem a year ago, see: Indicators stopped working
As TBM says, the feed for the indicators goes through the hazard switch. The feed is cut to the indicator circuit when the hazards are on, but the switch failed internally so that the current was permanently off.
I made a temporary fix by removing the hazard switch and wiring across the socket until I could get a replacement.
2011 Morgan 4/4
1932 Austin 7 Chummy
1 member likes this: gomog
Online NoMood
Well done! Covers all the symptoms and matches the diagram. It is the thingie my diagram is pointing to.
gmg
We have rocker switches in our 73 4/4. We had indicator problems too, and the issue was the hazard switch as stated above. I carefully took it apart and cleaned it. That fixed the issue. I ended up cleaning all of the rocker switches. After 50 years I guess they were due.
73 4/4 "Henry A"
53 +4 Flat Rad "Pug"
84 Citoen 2CV Spec "BeBe"
60 MGA
https://morgan34.org/
RMP Offline OP
Re no indicators
Thanks for all the info, all is well, it was the earth wire had detached from the flasher unit
RMP
1 member likes this: PaulyG
Originally Posted by RMP
Re no indicators
RMP
Glad you're sorted. My rule of thumb for anything electrical is to check the earth side first, I assumed it would be the connections at the rear where they are exposed, didn't think that it would be at the flasher end.
