Posts837,266
Posts: 101 |
I have to ask before I hurt myself or break something - is there a trick to removing the big nut on the RH side of the rear axle?
Over the winter, the rear brake seems to have bound so that there is drag and the rear wheel does not spin freely. I am trying to get the rear wheel off to service the brake. I’ve watched Phil Blealey’s video, but it just says remove the split pin and nut with no further detail. I’ve put all my weight on it to no avail. The hole for the split pin is still perfectly aligned with the castle nut. Do they have gorilla at the factory installing these things?
Scott
2018 M3W 1995 Porsche 993
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
You need an extra long spanner, the longer the better, mine is 550mm long, and then brute force.
1 member likes this:
PaulV |
Posts: 101 |
Thanks Rog. Kinda what I expected.
Scott
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
Have a look at Slogging Spanners on Ebay. You need a 36mm size and you can get it as a large ring spanner that you can slip a scaffold pole over....that will shift it!
Posts: 592 |
Two spanners with one lashed to the frame and the long one with all your body weight on it is about right.
M3W Brooklands (2015) Moody 41 (2013)
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
I think Andre the giant.....
Posts: 99 Likes: 5
Posts: 99 Likes: 5 |
My question is why is it so tight? The whole deal with a castellated nut is that you wouldn't apply a torque per se - finger tight plus two flats was what I was taught...
M3W 2017 Sport blue.
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
It needs a lot of tension in the spindle to get sufficient clamping force to hold it in place in the swing arm. It really wants to move out of alignment. hence the high torque.
LightSpeed |
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
It needs a lot of tension in the spindle to get sufficient clamping force to hold it in place in the swing arm. It really wants to move out of alignment. hence the high torque. What Calum said...
Posts: 79 Likes: 23
Posts: 79 Likes: 23 |
Since I changed the system, I do not have the problem of "the extreme tight issue" anymore. Just simple "Tied is Tied enough" because it can not move anymore. It still will take 2 extra adjustments after the first one, but that's it. See my new system https://www.talkmorgan.com/ubbthreads.php/topics/797606/a-better-rear-wheel-adjuster-system
One ant does not know anything, 2000 are a super-intelligent brain. That's like this helpful forum.
