0 members (), 336 guests, and 31 robots.
+8Rich 93
Posts837,277
#799936 04/05/24 08:11 PM
I have to ask before I hurt myself or break something - is there a trick to removing the big nut on the RH side of the rear axle?
Over the winter, the rear brake seems to have bound so that there is drag and the rear wheel does not spin freely. I am trying to get the rear wheel off to service the brake. I’ve watched Phil Blealey’s video, but it just says remove the split pin and nut with no further detail. I’ve put all my weight on it to no avail. The hole for the split pin is still perfectly aligned with the castle nut. Do they have gorilla at the factory installing these things?
Scott
2018 M3W
1995 Porsche 993
You need an extra long spanner, the longer the better, mine is 550mm long, and then brute force.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
1 member likes this: PaulV
Thanks Rog. Kinda what I expected.
Scott
2018 M3W
1995 Porsche 993
Have a look at Slogging Spanners on Ebay. You need a 36mm size and you can get it as a large ring spanner that you can slip a scaffold pole over....that will shift it!
I
I
Two spanners with one lashed to the frame and the long one with all your body weight on it is about right. farmer
M3W Brooklands (2015)
Moody 41 (2013)
I think Andre the giant.....
Rodger
2004 Plus 8 (wife's)
My question is why is it so tight? The whole deal with a castellated nut is that you wouldn't apply a torque per se - finger tight plus two flats was what I was taught...
M3W 2017 Sport blue.
It needs a lot of tension in the spindle to get sufficient clamping force to hold it in place in the swing arm. It really wants to move out of alignment. hence the high torque.
1 member likes this: LightSpeed
What Calum said...
Since I changed the system, I do not have the problem of "the extreme tight issue" anymore.
Just simple "Tied is Tied enough" because it can not move anymore.
It still will take 2 extra adjustments after the first one, but that's it.
See my new system https://www.talkmorgan.com/ubbthreads.php/topics/797606/a-better-rear-wheel-adjuster-system
One ant does not know anything, 2000 are a super-intelligent brain. That's like this helpful forum.
