5 members (Doug J, Peterkul, TeddyAds, Zach, Graham, G4FUJ), 327 guests, and 56 robots.
+8Rich 91
Topics49,841
Posts837,316
Obie #806625 29/08/24 06:33 PM
I'm looking to get a new rear brake line made, or maybe make one up myself. Can anyone confirm the spec of the fittings at both ends?
I think the 90 degree one that connects to the slave cylinder is 3/8" UNF?
Is the front one that connects to the 3 way union M10 and if so, is it M10x1.0 or M10x1.25?
Any recommendations for suppliers of the braided hose and fittings in the UK?
Andy
Obie #806638 29/08/24 08:22 PM
Andy, can't help with the thread specs, but can recommend CBS for your parts & pipe
https://www.carbuilder.com/collections/braking-and-clutch/self-assembly
Obie #806640 29/08/24 09:13 PM
HEL Performance have made brake lines for my M3W
https://www.helperformance.com/?ppc...94I2biAMVW5FQBh3gjwd2EAAYASAAEgJNEvD_BwE
I can’t remember the fitting sizes, but can let you know next week.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
Rog G #806736 31/08/24 09:13 AM
Originally Posted by Rog G
Thanks Rog. That HEL company is a real find. I found the website a bit overwhelming at first, but once I'd discovered the configurator, it was as easy as pie.
The standard plastic sleeving over the braiding which can be specified in a myriad of different colours is a bonus.
Having removed my old brake line, I can confirm that the fittings (on my 2012 car at least) are as follows.
Slave Cylinder Fitting:
90° Swivel Female (concave)
M10 x 1.00
Front Fitting (gearbox side of bulkhead adjacent to pedal box)
3/8” x 24 UNF
Some caution is needed here as M10x1.0 and 3/8" UNF threads are quite similar. An M10x1.0 female fitting will fit onto a 3/8" UNF male thread (albeit a tad loose) but NOT vice versa.
The length of the line on my 2012 car was 2.5m. The replacement I've ordered is 2.8m which I'm guessing is similar to that of later cars.
The cost (including the optional express delivery) was £56 which is around half the cost from MMC.
Andy
Obie #806737 31/08/24 09:20 AM
TBM Offline
I use venhill for my Morgan and Bike brake lines - similar to HEL - you choice your length of hose and fittings for the end.
https://www.venhill.co.uk/hydraulic-lines-and-fittings/powerhose-plus-lines-and-fittings.html
Bunny #806753 31/08/24 03:19 PM
M10 x 1.00
3/8” x 24 UNF
Those fittings are the same as mine, the metric fittings are identified by small nicks on the corners of the flats, UNF are plain.
Yes M10 will fit on 3/8 but will leak, don’t ask how I know.
Only Morgan would make them with different fittings at either end.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
Obie #807165 06/09/24 11:49 AM
This is what I ended up with.
The 2.8m length seems just right, allowing a nice 'spare' loop behind the seat. At first when I asked for the low profile forged end they threatened to charge me a surcharge, but in the end they just made it and shipped it. I received it next day. 1st class service from HEL I reckon. It was a fiddle to fit to the bulkhead fitting under the oil tank so I was glad that I'd asked for that low profile fitting.
Andy
1 member likes this: Bitsobrits
