1 members (Julian BB),
268
83
Topics49,847
Posts837,389
Posts: 1,065 Likes: 23
Posts: 1,065 Likes: 23 |
Yesterday I removed the frontwheels for a intensive clean.
But when I fit the left frontwheel the wheel was blocked. I think the pistons of the caliper don‘t work. For a check (and clean, and also some „ATE Bremsenfett“) I want to remove the caliper. So far no problem.
But for the correct fitting of the caliper, what‘s the correct torque for the caliper-screws.
Thank you for the help! And allways sorry about my bad english.
Greets René
2018 plus4 (sports green) with a homemade really shiny red tinted dash…
Posts: 2,086 Likes: 70
Posts: 2,086 Likes: 70 |
I think it may be that the brake pad has stuck to the disc, particularly if you have used water. I often get this problem if I have been out in the rain and then left the car for a few days. With the car on all four wheels, try moving it back and forth and you might hear a bang as the pads let go. If successful, you then need to clean up the rusty patch that will be seen on the disc.
1 member likes this:
xc68anc |
I think it may be that the brake pad has stuck to the disc, particularly if you have used water. I often get this problem if I have been out in the rain and then left the car for a few days. With the car on all four wheels, try moving it back and forth and you might hear a bang as the pads let go. If successful, you then need to clean up the rusty patch that will be seen on the disc. That‘s an idea and the first step. But the most times I‘m on the bad sides. You Knie: „The German Angst“ ;-) Greets René
As Doug said,
no fear, the brakepads where only a little „clued“ after the last journey in the wet. Out of the garage and a few miles, problem cured. Also checked: both fronthubs/ wheelnuts where cold.
Thank you!
Greets René
… but the next question…
Deejay |
