5 members (Pittsartist, Image, James B W, Robbie, Liam1961), 206 guests, and 73 robots.
+8Rich 94
Posts837,271
#811255 09/11/24 12:55 AM
MOG37 Offline OP
I seem to have some sort of vibration issue on the passenger side, underneath the armrest pad. It's quite loud at certain speeds. It's as though the panel, where it curves around over the frame, is vibrating against the frame itself. If, while driving, I reach over and grab that armrest area, the noise reduces considerably. I have removed the leather arm pad and it makes no difference to the vibration / noise.
Has anyone else experienced something similar? Not really sure what to do about it. Perhaps see if I can isolate the frame from the panel by placing a rubber strip between them?
24 Super 3
23 Super 3
21 M3W
15 M3W
05 V6 Roadster
68 MGB GT 3.9L V8
67 MM 1000 Tourer
Check the exhaust mounting bobbins for cracking.
Red Leader drive
1 member likes this: PaulV
MOG37 Offline OP
This seems to be the area where the noise is coming from. If I grab the top of the arm rest hard, the noise diminishes or goes away. Given there is arm rest, metal chassis, wood frame, and plastic panel wrapping over, I'm not sure what exactly is making the noise. It's very loud when the speed / vibration frequency is just right (or wrong!).
24 Super 3
23 Super 3
21 M3W
15 M3W
05 V6 Roadster
68 MGB GT 3.9L V8
67 MM 1000 Tourer
MOG37 Offline OP
The two rubber mounts under the exhaust on that side? I hadn't looked down there, but I suppose if one or both are cracked, any resulting excess movement might pull one surface onto another and cause the rattle? Is that your thinking?
24 Super 3
23 Super 3
21 M3W
15 M3W
05 V6 Roadster
68 MGB GT 3.9L V8
67 MM 1000 Tourer
Yes, if the exhaust is moving it could be exciting a vibration in the panel above. It's a bit of a long shot but a quick and easy check.
Red Leader drive
MOG37 Offline OP
I took another look this morning. It seems to be coming from the wood rail that runs along the top side of the tube frame there, ie under the wrap around red panel. There's a fastener on the RHS of the photo that shows where that rail runs - it's not very wide. I could fasten through the panel to the rail so the panel doesn't vibrate as much but, given the tone and loudness of the noise, I think it's actually the wooden rail vibrating on the metal frame.
Anyone heard of this? No pun intended.
24 Super 3
23 Super 3
21 M3W
15 M3W
05 V6 Roadster
68 MGB GT 3.9L V8
67 MM 1000 Tourer
There are so many vibratory sounds on these machines I'm surprised one stands out above the rest. frown
You might try silicone between the parts to both stabilize them and dampen the vibrations.
Late 2012 M3W
1 member likes this: MOG37
that is one of the advantages of presbycusis
Rodger
2004 Plus 8 (wife's)
MOG37 Offline OP
LOL! VA still has a helmet requirement for three-wheelers, right? Depending on the style, that could reduce noise (for you) too!
24 Super 3
23 Super 3
21 M3W
15 M3W
05 V6 Roadster
68 MGB GT 3.9L V8
67 MM 1000 Tourer
I wear my helmet always. It is a 50 year plus habit of riding motorcycles.
Rodger
