0 members (),
335
59
Topics49,844
Posts837,360
Posts: 526 Likes: 85
Posts: 526 Likes: 85 |
My helpful dealer says they are working on a solution... Glue.
Plus Six "Rachel" Volvo C40
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Is it the whole mirror arm that is folding or just the mirror part? I have a 2023 Plus Four so the older trad style mirrors. I replaced the original mirrors with Librands round ones as I preferred them for visibility. I seem to remember that there was a screw that tightened the mirror up so it stayed in position. I can check later. I can remember making O-rings to help seal and cushion the mirror, but that might have been on the previous car. This was at the ball/socket joint on the rear of the mirror. The grub screws holding the stem in the base were checked for tightness too but be careful there! The base arm is not hard material so care not to damage the thread is needed.
Posts: 27,807 Likes: 749
Posts: 27,807 Likes: 749 |
It is the whole arm that moves as the drag pulls it back.
Posts: 22 Likes: 26
Posts: 22 Likes: 26 |
For me, it's first the round mirror that tilts downwards, and then, as the speed increases, the arm that folds.
Supersport MY 2025
Posts: 3,847 Likes: 399
Posts: 3,847 Likes: 399 |
It always seems one step forward and two steps back, but eventually gets fixed (after a fashion)
22 Plus Four KIMI 12 Plus 4 Sport OZZY 08 Roadster FELIX 06 4/4 70th LOKI 77 4/4 SEAMUS 85 4/4 MOLLY
The old saying.... Morgan build the cars and the owners finish them.
My grumble about the Plus Four? The stupid position of the usb sockets tucked away at the back of the glovebox and no 12V socket anywhere.
Mind you, every car I have owned has had little things like this. Some small things that get me asking...why?
Posts: 17 Likes: 1
Posts: 17 Likes: 1 |
I have solved the problem of the folding mirrors on my Pus Six Pinnacle, flushed out all the grease from the internals using break cleaner and then filled with two part epoxy. Have tested to 115mph, not on public roads I hasten to add and works well. Still able to adjust mirrors at the head.
1 member likes this:
Plus Four Guy |
Posts: 514 Likes: 56
Posts: 514 Likes: 56 |
they may have designed them that way so the stress is removed from the mounting when your car is going fast!!!!!!
DB
Replace them by the Librands standard ones they look far nicer
CooperMan |
