Topics49,841
Posts837,318
Posts: 19 Likes: 1
Posts: 19 Likes: 1 |
It's time to SORN one of my three wheelers. In the past I've had to do this every year, but the advice now seems to be that I don't have to renew annually.
Is this correct?
Alan 1934 SS 1935 F2 2006 Roadster 4 str
2006 4 str Roadster 1934 Super Sports 1935 F2
Posts: 1,013 Likes: 119
Posts: 1,013 Likes: 119 |
Don't know! My friend got a fine a couple of years ago as he had failed to notify the DVLA that his was still SORN.
Posts: 6,954 Likes: 115
Posts: 6,954 Likes: 115 |
According to Gov.UK, you don't need to renew unless you tax it again and then take it off roed.
Posts: 1,079 Likes: 71
Posts: 1,079 Likes: 71 |
My understanding is the vehicle has to be either taxed or SORN'd, once SORN'd this stays in place until you re-tax the vehicle again.
David Aero S4
Posts: 472 Likes: 70
Posts: 472 Likes: 70 |
If it's earlier than 1984 then it's zero tax anyway so no need to SORN
1956 Plus 4 4 seater
Posts: 526 Likes: 85
Posts: 526 Likes: 85 |
A zero tax vehicle still has to be taxed, se even if zero tax I would suggest you still need to SORN.
Plus Six "Rachel" Volvo C40
Posts: 12,256 Likes: 317
Posts: 12,256 Likes: 317 |
My understanding is the vehicle has to be either taxed or SORN'd, once SORN'd this stays in place until you re-tax the vehicle again. Yep, this is my understanding too. Tax (even at zero level) has to be renewed each year, but SORN lasts until it is removed.
Posts: 8,667 Likes: 489
Posts: 8,667 Likes: 489 |
If it isn't already SORN, then you need to ping it as such with the DVLA or the 'puter will issue an automatic fine If you think it's already SORN, just check here with the reg to make sure https://www.gov.uk/check-vehicle-tax
Thanks CooperMan, very clear. I tax my car annually and SORN it when the weather gets nasty. It used to be a more financially proficient way as 6 months costs more and you don't know when you want to take it of the road, ie. indian summer etc. probably need to look at it again as I really don't use the car enough and 6 months would probably cover my needs now.
P.S. My mate probably got a fine because he forgot to SORN it when the tax expired...... He does have his head up his ..... in the clouds most of the time! Not surprising that he couldn't get why he was fined then!
Posts: 5,945 Likes: 28
Posts: 5,945 Likes: 28 |
If it isn't already SORN, then you need to ping it as such with the DVLA or the 'puter will issue an automatic fine If you think it's already SORN, just check here with the reg to make sure https://www.gov.uk/check-vehicle-taxA splendid example of bureaucracy by the jobsworths. If you can keep SORN on a vehicle, why cant you keep zero tax on a vehicle. They might say that you could scrap the car and it still be registered if you did that - but so what?
