7 members (DCH, Hamwich, Nickplus4, Alan Patterson, MJF, nestor59310, Saxonian),
214
74
Topics49,870
Posts837,668
Posts: 37,435 Likes: 978
Posts: 37,435 Likes: 978 |
No need to get angry with screwdrivers and chisel. This inexpensive strap wrench tightens grip as you turn. 100% agree with this, The metal "strap" is great to squeeze into the tight space around the filter. I have a plastic handled rubber strap remover which is far better than the chain wrench as it never slips - in use for 30 years now.
Posts: 8,684 Likes: 493
Posts: 8,684 Likes: 493 |
I recently had to resort to my trusty chain and breakers bar to shift a filter off some old vauxhall engine for a pal, goodness knows who'd fitted it last !
On mine it's fitted to a half inch socket which distorts the filter as it bites, as way say oop north...shifts owt !
Happy Birthday Jon
1 member likes this:
CooperMan |
Posts: 8,684 Likes: 413
Posts: 8,684 Likes: 413 |
Have a good one Jon
CooperMan |
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
CooperMan |
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
Just be careful you don't damage the sensor which is next to the filter during your strenuous efforts!!!!!!!!
Posts: 263 Likes: 2
Posts: 263 Likes: 2 |
Today my new oil filter remover arrived, I bought a Spurtar adjustable oil filter wrench 60-80mm, which I could just about get onto the filter. Even with it the oil filter wasn't easy to remove. It must have been put on by a gorilla but thankfully the job is now done.
2021 Morgan Plus Four 2012 Morgan Three Wheeler 2020 Land Rover Defender 110
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Did you try the large socket device that fits the end of the filter? It attaches to a socket wrench.
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
I have both the adjustable strap as well as the socket. Strap works every time. The socket sometimes doesn't as the oil filter may have the right indentation or none at all.
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
Something to consider for the future, the K&N Filter KN171B has a socket drive on the bottom and makes this a much easier operation than the original S&S 31-4103 filter. You can also wire lock them on for extra security if you fancy. It filters pretty much the same and costs less as well. Chain wrenches won't fit with the M3W as the clearance is small around the filter, some strap wrenches work though. These filters don't need screwing up like your life depends on it, just a nip.
