8 members (James B W, Image, Robbie, Liam1961, nick w, MJF, Pittsartist, John Wilcox),
230
65
Posts837,271
Posts: 28 Likes: 11
Posts: 28 Likes: 11 |
Sounds like very substantial progress Martin - a really useful report.
Did you run any additional seal around the inner face of the bottom of the doors ? (where they seal against the car body below the door aperture). In addition to the other areas you have noted, on mine, there are gaps along this section and these seem a possible cause of some water ingress onto the stainless steel scuff plate that runs around the door aperture when it rains or I use the screenwash (another possibility is that water is getting driven in past the hinges at the door front edges - again by the slipstream). I'm having the draughts / leaks and possible misalignment of the door (hinging angles) with respect to the car body - both sides - looked at under warranty in March.
Posts: 3,846 Likes: 398
Posts: 3,846 Likes: 398 |
I've spent a couple more sessions on the passenger side door, sidescreen and hood gaps. I have used nearly 3 metres of neoprene 1/2" 'D' profile seal, from woollies. Hope what follows makes sense / might be of use to someone.
On mine, investigation suggested there were three main areas for attention: - Vertical rear edge of the door and sidescreen. I had to run the new seal from top to bottom (in two halves, to allow sidescreen removal). I still had a slight draft until I added an extra run of seal on the door. This has nearly completely stopped the draft. - Front half of the top of sidescreen to hood join: There is already a factory seal on the hood frame, split into two lengths, to allow the frame to hinge when being collapsed. This seals adequately against the sidescreen, but I still had a gap between the hood and the frame. I ran a length of seal above the front half of the factory seal. This needed Evostick contact adhesive, to make firm. When the hood's up, this now touches the hood and closes the gap. It doesn't interfere with collapsing the hood. - Where the sidescreen and door meet at the front edge and also seal against the bulkhead beneath the bottom of the windscreen. There was a significant draft from this area, blowing into the cabin around the left end edge of the dashboard roll-top. This took the longest to fix, but I've managed it with a couple of parallel strips of seal along the bulkhead, in line with the top of the door and a single seal on the fabric section of the sidescreen, front edge to the chrome sidescreen attachment bracket. That's pretty much fixed it. I'm not sure how well the seal's pre-applied 3M adhesive will work on the sidescreen material. I may need some evostick here, time will tell.
None of the seals added are visible with the door closed, nor with the sidescreen off. They aren't noticeable with the door open, unless you know what you're looking for. Even then, the D seal looks reasonably like it was built that way. The result is much less draft, a significant improvement, not totally eradicated, but now perfectly acceptable. I also think the wind noise is reduced. This improvement is noticeable, but not significant. 👍 It would be helpful if you could post some pictures.
22 Plus Four KIMI 12 Plus 4 Sport OZZY 08 Roadster FELIX 06 4/4 70th LOKI 77 4/4 SEAMUS 85 4/4 MOLLY
Posts: 139 Likes: 27
Posts: 139 Likes: 27 |
Did you run any additional seal around the inner face of the bottom of the doors ? (where they seal against the car body below the door aperture). In addition to the other areas you have noted, on mine, there are gaps along this section and these seem a possible cause of some water ingress onto the stainless steel scuff plate that runs around the door aperture when it rains or I use the screenwash (another possibility is that water is getting driven in past the hinges at the door front edges - again by the slipstream). I'm having the draughts / leaks and possible misalignment of the door (hinging angles) with respect to the car body - both sides - looked at under warranty in March. Hi, no, I don't think I have any problems there. My doors were checked and had slight adjustments made by Krazy Horse at my service last month. It didn't fix the draughts, but it might have helped, starting from a decent door alignment.
Plus Six '75 Commando 850 '76 CB750K6
It would be helpful if you could post some pictures. I'll take some tomorrow and try to remember how to upload.
Posts: 665 Likes: 31
Posts: 665 Likes: 31 |
Posts: 525 Likes: 85
Posts: 525 Likes: 85 |
Plus Six "Rachel" Volvo C40
Photos of the seals added to the passenger side. The first is the D seal added to the front of the soft top frame, above the factory seal: ![[Linked Image]](https://www.talkmorgan.com/gallery/26/full/42471.jpg) Next the new seal is on the inside of the rear edge of the sidescreen: ![[Linked Image]](https://www.talkmorgan.com/gallery/26/full/42469.jpg) Next photo is the rear of the door below the sidescreen, showing seals on the bottom fabric area of the sidescreen and the door panel. There was already a flat closed cell foam seal by the door catch. I don't know if that's standard, or added by Krazy Horse: ![[Linked Image]](https://www.talkmorgan.com/gallery/26/full/42472.jpg) Finally, the seals on the front area of the door and on the sidescreen: ![[Linked Image]](https://www.talkmorgan.com/gallery/26/full/42470.jpg) The driver's side wasn't as bad. It has some of the same seals on the rear of the door, only one on the front and nothing needed on the hood frame. Hope the photos upload OK for you. Sorry the orientation is wrong on some of them. They are also in the photos section somewhere on the forum!
2 members like this:
JohnHarris, Plus Four Guy |
The first photo also shows a neat little elasticated pocket, attached (by supplied 3M tape) to the passenger side of the transmission tunnel. I found this at Halfords for £6!
I run the USB cable out of sight to the little pocket and store and charge my phone there.
I asked Krazy Horse how much to fit the factory version and was estimated somewhere north of £300. So I feel like I found a bargain 😁
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
Its good to see someone taking up the baton of using neoprene seals on the CX cars!
1 member likes this:
MartO |
