Topics48,341
Posts812,981
Posts: 99 |
hi chaps, whats the best way to wire in a tom tom sat nav, this is the 1st car ever that did not have some form of ux wiring build in. michael
Posts: 2,515 |
I bought a cigarette lighter socket from a breakers for a couple of quid and wired it up to a suitable fuse.
1972 4/4 2 Seater
Posts: 3,643 |
Michael, have a look under the dash near the glove box, there may be a 12v socket there.
Posts: 510 Likes: 1
Posts: 510 Likes: 1 |
My '86 4/4 didn't have one, I bought an auxy socket from Maplin and an in line fuse. Mounted the socket in the upright between and behind the two seats and wired straight to the battery via the fuse. Worked OK. My 2002 4/4 has a socket in the glove compartment.
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon 2023 AMG Mercedes C300e estate 2021 Audi A1 sport
Posts: 859 Likes: 1
Posts: 859 Likes: 1 |
Some cars even have the socket inside the glove box
Honda S2000 Lexus UX 250h Toyota Auris Hybrid
Posts: 2,054 Likes: 18
Posts: 2,054 Likes: 18 |
If your car is new(ish) then there should be one fitted. Mine is in the glove box (on the right-hand side)
Regards Alan AP08 MOG 2016 Plus 4 GDi - Mazda Soul Red Metallic
Posts: 14,723 Likes: 149
Posts: 14,723 Likes: 149 |
Being a 2010 model I am almost certain that you will find a lighter socket under the right hand side of the glovebox facing down towards the floor. It will have a flip off plastic cover that is held on one side.
Finding a place to mount the sat nav is another story (there is a thread on this topic). If you have the walnut dash the surface is probably smooth enough and shiney enough that you can stick it onto the dash up high between the glovebox and the instrument panel. That is where we put ours.
Posts: 1,004 |
If you have the walnut dash the surface is probably smooth enough and shiney enough that you can stick it onto the dash up high between the glovebox and the instrument panel. That is where we put ours. [/quote] Ditto!
Posts: 388 |
On my 2006 4/4 anniversary the socket is behind the dashboard near the dimmer for instrument panel.
Keep mogging,
Christian
2006 4/4 70th anniversary, 1985 VW 1200 50th anniversary, 1977 Vespa 50 Special, 2003 Vespa PX 200E
Posts: 99 |
Thanks chaps, will have a look. michael
