7 members (MATTMOG, sewin, Rovert, KBMOG, howard, MDS61, Chris99), 305 guests, and 43 robots.
John V6 70
DaveW 66
+8Rich 66
9,208 Registered Users
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Topics48,341
Posts812,996
RedThree
#97703 10/07/12 11:05 AM
hi chaps, whats the best way to wire in a tom tom sat nav, this is the 1st car ever that did not have some form of ux wiring build in. michael
terry1956 #97704 10/07/12 11:15 AM
I bought a cigarette lighter socket from a breakers for a couple of quid and wired it up to a suitable fuse.
1972 4/4 2 Seater
tmg513 #97705 10/07/12 11:22 AM
Michael, have a look under the dash near the glove box, there may be a 12v socket there.
Ian
Wirewheel #97710 10/07/12 12:01 PM
My '86 4/4 didn't have one, I bought an auxy socket from Maplin and an in line fuse. Mounted the socket in the upright between and behind the two seats and wired straight to the battery via the fuse. Worked OK.
My 2002 4/4 has a socket in the glove compartment.
Simon
2002 4/4
2021 Audi A1 sport
Wirewheel #97711 10/07/12 12:02 PM
Some cars even have the socket inside the glove box
Honda S2000
Lexus UX 250h
Toyota Auris Hybrid
NeilM #97718 10/07/12 12:31 PM
If your car is new(ish) then there should be one fitted. Mine is in the glove box (on the right-hand side)
Regards
Alan
AP08 MOG
Alan Patterson #97730 10/07/12 01:05 PM
Being a 2010 model I am almost certain that you will find a lighter socket under the right hand side of the glovebox facing down towards the floor. It will have a flip off plastic cover that is held on one side.
Finding a place to mount the sat nav is another story (there is a thread on this topic). If you have the walnut dash the surface is probably smooth enough and shiney enough that you can stick it onto the dash up high between the glovebox and the instrument panel. That is where we put ours.
Gambalunga #97731 10/07/12 01:08 PM
If you have the walnut dash the surface is probably smooth enough and shiney enough that you can stick it onto the dash up high between the glovebox and the instrument panel. That is where we put ours. [/quote]
Ditto! smile
Moss #97735 10/07/12 01:19 PM
On my 2006 4/4 anniversary the socket is behind the dashboard near the dimmer for instrument panel.
Keep mogging,
Christian
2006 4/4 70th anniversary, 1985 VW 1200 50th anniversary, 1977 Vespa 50 Special, 2003 Vespa PX 200E
4acker #97747 10/07/12 03:05 PM
Thanks chaps, will have a look. michael
