5 members (jbk, Image, Hamwich, Farmershands, High Hamster), 216 guests, and 71 robots.
Posts837,248
Thread Like Summary
AZJowett, Bunny
Total Likes: 3
#844571 06/05/2026 3:22 PM
by AZJowett
AZJowett
Does anyone have drawings or diagrams of the following:
1. S&S Engine Stand 53-0147 - To build a stand for an **S&S X-Wedge 121 engine**, you must use the **four mounting points on the lower cases** and a **top support brace** connecting the cylinder heads.
2. **top support brace** connecting the cylinder heads for lifting with a hoist. The S&S manual specifies that the top support brace must connect the **3/8”-16 tapped bolt holes** located on top of each cylinder head above the intake port using **7/16” Grade 8 bolts**.
Time to swap engines...
Thank you all for your collective wisdom!
Liked Replies
#844579 Jun 5th a 06:36 PM
by Socalm3w
Socalm3w
Good luck with the swap!
This is a drawing Bleazey sent me when I asked him. I ended up buying the S&S engine stand.
1 member likes this
#844930 Jun 13th a 06:24 AM
by planenut
planenut
All the X-Wedge engines supplied to Morgan were fitted with a lifting bracket, Morgan removed them and threw them in a scrap box. I was fortunate to get one when I was on a visit to the factory once. It's been used a few times since!
1 member likes this
#847077 Jul 25th a 06:28 PM
by planenut
planenut
I cannot take the credit for the engine stand, just the engine sling bracket....that you didn't use 😁. Good luck with all the work. Always good to see owners working on their cars.
1 member likes this
