5 members (jbk, Image, Hamwich, Farmershands, High Hamster), 216 guests, and 71 robots.
Posts837,248
#844571 05/06/26 03:22 PM
Does anyone have drawings or diagrams of the following:
1. S&S Engine Stand 53-0147 - To build a stand for an **S&S X-Wedge 121 engine**, you must use the **four mounting points on the lower cases** and a **top support brace** connecting the cylinder heads.
2. **top support brace** connecting the cylinder heads for lifting with a hoist. The S&S manual specifies that the top support brace must connect the **3/8”-16 tapped bolt holes** located on top of each cylinder head above the intake port using **7/16” Grade 8 bolts**.
Time to swap engines...
Thank you all for your collective wisdom!
2018 S&S 110th Beetleback
1934 MX4 Beetleback (in restoration)
1965 Corvette Coupe 327/350
AZJowett #844579 05/06/26 06:36 PM
Good luck with the swap!
This is a drawing Bleazey sent me when I asked him. I ended up buying the S&S engine stand.
1 member likes this: Bunny
AZJowett #844714 08/06/26 02:02 PM
Socalm3w - thank you so much for this!!!! Another true example of the Bleazey genius at work. Does anyone know if Phil also had a drawing of the top support brace?
AZJowett #844716 08/06/26 02:56 PM
I found in my notes there is a YouTube video of Emil’s way of removing the engine. It goes over using a length of rope instead of a metal plate to lift engine. Worked perfectly for me.
[video:youtube]
[/video]
AZJowett #844722 08/06/26 04:38 PM
I have this and mostly all his other videos also. I like Emil's work and helped him write a number of his modification installation guides. Just hoping the lift bar details were available. Thank you for all your help!
AZJowett #844930 13/06/26 06:24 AM
All the X-Wedge engines supplied to Morgan were fitted with a lifting bracket, Morgan removed them and threw them in a scrap box. I was fortunate to get one when I was on a visit to the factory once. It's been used a few times since!
AZJowett #845099 17/06/26 04:08 AM
Not being an engineer myself, is there a way to scan it for dimensions?
AZJowett #845708 28/06/26 05:11 PM
Thank you Planenut for all your help!
X-Wedge Engine Stand
AZJowett #846999 24/07/26 02:14 AM
Here is my progress thanks to so many who contribute. Funny thing is the clutch plate has a note on it saying "Flywheel Side" but is was installed backwards it looked like. Next strep is getting some work done.
[img]https://www.talkmorgan.com/ubbthreads.php/galleries/846998#lg=846998&slide=0[/img]
[img]https://www.talkmorgan.com/ubbthreads.php/galleries/846998#lg=846998&slide=1[/img]
[img]https://www.talkmorgan.com/ubbthreads.php/galleries/846998#lg=846998&slide=2[/img]
AZJowett #847077 25/07/26 06:28 PM
I cannot take the credit for the engine stand, just the engine sling bracket....that you didn't use 😁. Good luck with all the work. Always good to see owners working on their cars.
1 member likes this: AZJowett
