8 members (linklaw, Cat302, 231, Baristas, vincentvg, IcePack, DJC, jejemek),
223
71
Topics49,851
Posts837,443
Misting Gauge
I've never driven a Morgan before and I was quite surpised to see misting in two out of three gauges. However this seems to be a known issue: Maintenance and Servicing: Workshop note - Misting gauges Is this a common issue or a rather rare occurrence?
Posts: 2,779 Likes: 5
Posts: 2,779 Likes: 5 |
My plus 4 did it regularly. The Healey doesn't once the normal footwell temperature gets up to shoe melting capability. Agree the fuel gauge is the worst for it.
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
The speedo on my Aero +8 mists up once the ambient temperature is below 19c.
I wonder if changing the glass for perspex would be the answer? Quite hard to do I should think.
+8 4.8
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Posts: 1,947 |
The glass fronted instruments on my 1930 Sunbeam tourer never mist up. The polycarbonate instruments on my Piaggio scooter used to mist.
Posts: 27,810 Likes: 749
Posts: 27,810 Likes: 749 |
I went for LED bulbs, now only the fuel gauge is an issue and it is not as bad as the heating effect is lower. But I have single gauges.
The LED light though is bright white so I am trying with bulbs painted with yellow headlight paint to see if that helps tone it down a bit.
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
If Lucozade bottles still come wrapped in yellow plastic you could use that. Or try some orange Lens repair tape.
Posts: 6,957 Likes: 116
Posts: 6,957 Likes: 116 |
If Lucozade bottles still come wrapped in yellow plastic you could use that. They do.
Too late flashed the £2 on the paint.
