8 members (MATTMOG, CooperMan, Phil63, Topline123, RichardV6, Bunny, Black Adder, chanteclair),
315
Topics48,343
Posts813,019
Posts: 632 Likes: 6
Posts: 632 Likes: 6 |
In Fords the Duratec is normally covered by a plastic cover and a waterproof bonnet. In a Morgan water flows down through the louvres and into the wells causing ignition problems and rust. Cosworth has a nice carbon fibre coil cover which could help to solve this problem. Does anybody know if this cover fits the cam cover on the Plus 4? Harald
Posts: 14,976 Likes: 1
Posts: 14,976 Likes: 1 |
I would imagine the cam cover is a stock item that Morgan take I react from Ford.
Richard 1976 4/4 4 Seater
Posts: 169 |
Caterham do a similar cover which is a lot more cost effective.
Posts: 3,425 Likes: 26
Posts: 3,425 Likes: 26 |
Andrewr, Do you know where such a cover can be bought -- I have looked at Caterham's site and can't find mention of it
Cheers!
Posts: 632 Likes: 6
The Caterham coil cover is out of stock. Harald
Cheers! Burton Power supply these.
Posts: 198 |
I found a piece of automotive plastic on the roadside, it was the right shape. Took it home cut it to length, fitted the spine of a (4) lever arch file, trimmed the arms and covered them with small diameter fuel hose. The arms needed a spacer to keep the pressure on and make a snug fit. I also fitted a length of 5m bolt into a casting sleeve on the cam cover and fixed it with a butterfly nut. Low cost solution and no water ingress! All the best Tony
I found a piece of automotive plastic on the roadside, it was the right shape. Took it home cut it to length, fitted the spine of a (4) lever arch file, trimmed the arms and covered them with small diameter fuel hose. The arms needed a spacer to keep the pressure on and make a snug fit. I also fitted a length of 5m bolt into a casting sleeve on the cam cover and fixed it with a butterfly nut. Low cost solution and no water ingress! All the best Tony Effective Tony!
Posts: 198 |
Some photos /camcover2_zpsd2e6a004.jpg.html]  [/URL]]Cam Cover[/url]  ]Cam Cover[/url]
