8 members (DavidR, John V6, Bishmog, chanteclair, HeadlessBlue, Graham, G4FUJ, MATTMOG, John07), 261 guests, and 43 robots.
+8Rich 64
Adam12 62
John V6 57
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,319
Members9,215
Soleng Offline OP
In Fords the Duratec is normally covered by a plastic cover and a waterproof bonnet. In a Morgan water flows down through the louvres and into the wells causing ignition problems and rust. Cosworth has a nice carbon fibre coil cover which could help to solve this problem. Does anybody know if this cover fits the cam cover on the Plus 4?
Harald
I would imagine the cam cover is a stock item that Morgan take I react from Ford.
Caterham do a similar cover which is a lot more cost effective.
Andrewr,
Do you know where such a cover can be bought -- I have looked at Caterham's site and can't find mention of it
Cheers!
Robbie
2021 Plus Four -- Helga
211-WX-1433
Soleng Offline OP
The Caterham coil cover is out of stock.
Harald
Originally Posted By Robbie
Andrewr,
Cheers!
Burton Power supply these.
I found a piece of automotive plastic on the roadside, it was the right shape. Took it home cut it to length, fitted the spine of a (4) lever arch file, trimmed the arms and covered them with small diameter fuel hose.
The arms needed a spacer to keep the pressure on and make a snug fit. I also fitted a length of 5m bolt into a casting sleeve on the cam cover and fixed it with a butterfly nut.
Low cost solution and no water ingress!
All the best
Tony
All the best
Tony
Effective Tony!
Some photos
/camcover2_zpsd2e6a004.jpg.html][/URL]]Cam Cover[/url]
]Cam Cover[/url]
Neat job
