7 members (Saxonian, Steve +8, John Winn, Bishmog, JohnHarris, MJF, RichardV6), 308 guests, and 42 robots.
John V6 68
+8Rich 66
DaveW 64
9,208 Registered Users
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
Topics48,346
Posts813,054
Captain Morgan, IRWIN
Soleng Offline OP
In Fords the Duratec is normally covered by a plastic cover and a waterproof bonnet. In a Morgan water flows down through the louvres and into the wells causing ignition problems and rust. Cosworth has a nice carbon fibre coil cover which could help to solve this problem. Does anybody know if this cover fits the cam cover on the Plus 4?
Harald
I would imagine the cam cover is a stock item that Morgan take I react from Ford.
Caterham do a similar cover which is a lot more cost effective.
Andrewr,
Do you know where such a cover can be bought -- I have looked at Caterham's site and can't find mention of it
Cheers!
Robbie
2021 Plus Four -- Helga
211-WX-1433
Soleng Offline OP
The Caterham coil cover is out of stock.
Harald
Originally Posted By Robbie
Andrewr,
Cheers!
Burton Power supply these.
I found a piece of automotive plastic on the roadside, it was the right shape. Took it home cut it to length, fitted the spine of a (4) lever arch file, trimmed the arms and covered them with small diameter fuel hose.
The arms needed a spacer to keep the pressure on and make a snug fit. I also fitted a length of 5m bolt into a casting sleeve on the cam cover and fixed it with a butterfly nut.
Low cost solution and no water ingress!
All the best
Tony
All the best
Tony
Effective Tony!
Some photos
/camcover2_zpsd2e6a004.jpg.html][/URL]]Cam Cover[/url]
]Cam Cover[/url]
Neat job
