7 members (mph, SteveMerch, +8Rich, JohnHarris, Michael H, Grumpy2, BrunswickGreen44),
331
34
SORN
New
Topics48,369
Posts813,476
Members9,215
Posts: 1,944 |
Crowbar the boot lid is going to act like an air brake. Suggest you fit a restraint so it cannot open up fully. Tim
Posts: 410 Likes: 5
Posts: 410 Likes: 5 |
Thanks guys...
The car has 1400 miles, the sound really seems to emanate from behind the seats...my impression is that compensator issues should emanate more forward...
1965 Plus 4 2008 997 Turbo Cab 1981 Alfa Spider 1954 Austin Healey 100 (SOLD) 2013 M3W (SOLD)
Posts: 410 Likes: 5
The sound really *seems* to emanate from behind the seats - not up front at the compensator...but perhaps it's just traveling down the transmission tunnel and exiting out the back.
Can anyone who has had a compensator failure tell me where the sound emanated from while driving?
Interestingly, the sound is absent when the car isn't moving.
Posts: 3,827 Likes: 4
le Asbo du Bling Talk Morgan Addict
Posts: 3,827 Likes: 4 |
Are you sure it not a loose bolt, it might be worth removing the seats to check the bolts are tight.
Slowly going green
Posts: 1,790 Likes: 3
Posts: 1,790 Likes: 3 |
Mine sounded like a bag of nails moving or not. In fact it drowned out the engine eventually.
Posts: 6,538 |
MMmmm well if it was the Compensator you would hear it clearly from the front of the car - not the rear:(( The sound would be there when the car is stationery too. Check all nuts/fixings etc - am sure that u already have!
Neil
Posts: 410 Likes: 5
m3boy...
My thoughts exactly...
This is something in the drivetrain, because it stops when the clutch is applied - which is why I don't think this is simply a loose bolt on the frame or chassis.
I don't think it's the compensator, as it's not coming from the front of the car, and it's absent when the car is running but stationary.
I need to take the car apart and drive it a little to localize the part...
Posts: 1,338 |
Do the steps i did,when changing the bevel box oil..look around,move things,it might be a loose bolt or washer around/under the belt
Posts: 2,777 Likes: 60
Posts: 2,777 Likes: 60 |
When my compensator was beginning to pack up the noise was "definitely" from the front right suspension and only when going over bumps and it wasn't just me that thought this. As it got worse it reached a point when it was rattling even when stationary in neutral at idle which confirmed the diagnosis. I wouldn't discount a failing compensator just yet. The way that mechanical noises can seem to migrate around the car, presumably due to assorted resonances is both impressive and a bit maddening. Best of luck tracking it down.
Posts: 797 |
Definitely the compensator. Mine sounded just like that. With the clutch depressed the compensator is doing even less work so that may be why the noise disappears. Do you hand blue black grease visible in the bell housing cut out under the steering rack? if so it's the compensator seals.
