8 members (Robbie, Paul F, Hamwich, planenut, Whizjet, DavidR, BerndE, BLUE+4),
455
41
SORN
New
Topics48,375
Posts813,510
Members9,215
Posts: 1,639 Likes: 20
Posts: 1,639 Likes: 20 |
This has been on my “to do” list for a long time now. My fuel gauge has always been biased in one direction. When the tank is filled the needle remains hard pushed up against the end stop (almost out of sight) until I’ve used about 3 gallons, then it starts to fall normally. So I thought I would post my attempt at a bit of re calibration. Step.1 Find a suitable potentiometer to put in series with the gauge. Fill the tank, start engine and adjust pot until the needle just comes up to the full point. Step.2 Measure the pot. Step.3 Source a fixed resistor of a similar value (15 Ohm) and attach to gauge. The needle now looks better positioned when full. Only time will tell if it performs over the entire the range.
Roger 2011 Plus 4
Posts: 3,643 |
Nice one Roger, I hope it works.
Posts: 6,830 Likes: 59
Posts: 6,830 Likes: 59 |
Nice bit of crimping work.
Posts: 26,766 Likes: 427
Posts: 26,766 Likes: 427 |
I have been runnig the roadster with the sidelights on as some folk don't see the car as it is dark blue.
But the gauges then mist up. Rog are those holes in what looks like the botom of your gauges drain holes?
John, the holes are at the top of the gauges and are original. I assume they are breather/vent holes.
Roger 2011 Plus 4
Cheers will have to take a look somehow
Posts: 3,547 Likes: 4
Posts: 3,547 Likes: 4 |
If its a smiths gauge and sender it's supposed have a 10 volt regulator according to some sites.
I have yet to see if mine has said regulator.
A little late but I have just been asked for some results regarding this old post.
After adding the resister I did three tests. I measured the amount of fuel needed to fill the car from the ¾, ½ and ¼ gauge positions. Not very scientific but I tried to be as precise as possible. I used the same pump and filled to the first click. I remember just driving around to use up fuel until the right moment to top up again.
¾ full = 17.5 litres (to top up) ½ full = 27 litres ¼ full = 38 litres
My tank holds 55 litres, I have not done any testing below ¼ full and I only ever did the three tests.
Roger 2011 Plus 4
