7 members (RobC, JMcL, TalkMorgan, RedThree, Liam1961, Rudolf, TBM),
301
84
Topics49,859
Posts837,469
Posts: 797 |
Posts: 5,210 |
And for regular cars (not the case with trucks and lorries) the first inspection is only when they reach 4 years after build. Then 6, then 8, then every year.
In South Africa vehicles only have to be inspected whenever they change ownership and go through a rather flimsy "Roadworthy" certificate. Explains why so many wheels drop off really ancient cars and there are so many bad accidents....
Posts: 582 |
Great diagram Charles, but on my 2012 its a bit random. I would however love to get my hands on a true (readable) wiring diagram?
Posts: 1,947 |
In case they fit, this firm give good customer service, and usually work out cheaper than Holdens: Staffordshire Vehicle Components My two speeder has their headlights, and it is a quite common modification to enable the use of modern bulbs in an old car.
Posts: 522 Likes: 1
Posts: 522 Likes: 1 |
Great diagram Charles, but on my 2012 its a bit random. I would however love to get my hands on a true (readable) wiring diagram? I doubt there is a single wiring diagram in the public domain. My understanding is that there are broadly three electrical systems. 1)The s&s VFI wiring harness which is in the x wedge manuals. This concerns engine management including emissions. 2) the morgan system for the instrument binnacle, fuel pump etc. 3) the cycle electric alternator and rectifier for charging the battery. I dont know if the speedo, indicator and urban coolong kit are run from an ecu in the instrument binnacle or are part of the s&s vfi ecu
Posts: 797 |
Thanks Martyn These look good. Will post when fitted You wouldn't believe how thin the wiring going to the lights is. I wouldn't use it for signal cabling!!!,
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
The urban cooling fan must take an input from the ECU as I understand it the fan kicks in below 10mph and if you are below 10mph the indicators stay on. Therefore both are speed sensitive and I would assume use the same ECU output.
By the way does anyone know what the black plastic box full of relays is for stuffed under the fuse box/ECU?
Posts: 1,671 |
So that's the MOT Passed but with wheel Bearing advisories - but then again maybe there's supposed to be some play came the explanation - Had to tighten the headlights too. As for the knock on two ear spinners - from Morgan " it's down to the MOT testers discression" - Mmmmmm food for thought for another year anyway
Posts: 28 |
My M3W has just pasted her first MoT. I live over 100 miles from the nearest Morgan Agent so had to look for a more convenient provider. No problem, just go where the motor cyclist go; 16 miles.
Benfro Mog
Posts: 7,363 |
My M3W has just passed its MOT, no advisories or issues with two-eared spinners or anything else. The MOT station are however used to Morgan's and thus are used to their foibles!
Brian
1970 Morgan Plus 8 - Moss Box (Indigo Blue) 2014 Morgan SP1 (Rocket Red) 2015 Morgan Plus 8 (Rocket Blue)
