3 members (JohnHarris, Aeromax51, Alistair), 356 guests, and 93 robots.
+8Rich 86
Sagging Hood
Topics49,853
Posts837,447
Page 3 of 4 1 2 3 4
Matty Offline OP
Cheers will copy
MarioCP #270974 28/04/15 06:17 PM
Originally Posted By MarioCP
And for regular cars (not the case with trucks and lorries) the first inspection is only when they reach 4 years after build. Then 6, then 8, then every year.
In South Africa vehicles only have to be inspected whenever they change ownership and go through a rather flimsy "Roadworthy" certificate. Explains why so many wheels drop off really ancient cars and there are so many bad accidents....
Roger
Matty #270976 28/04/15 06:25 PM
Great diagram Charles, but on my 2012 its a bit random. I would however love to get my hands on a true (readable) wiring diagram?
hbatts #271034 28/04/15 09:29 PM
In case they fit, this firm give good customer service, and usually work out cheaper than Holdens:
Staffordshire Vehicle Components
My two speeder has their headlights, and it is a quite common modification to enable the use of modern bulbs in an old car.
hbatts #271043 28/04/15 10:32 PM
I doubt there is a single wiring diagram in the public domain.
My understanding is that there are broadly three electrical systems.
1)The s&s VFI wiring harness which is in the x wedge manuals. This concerns engine management including emissions.
2) the morgan system for the instrument binnacle, fuel pump etc.
3) the cycle electric alternator and rectifier for charging the battery.
I dont know if the speedo, indicator and urban coolong kit are run from an ecu in the instrument binnacle or are part of the s&s vfi ecu
Matty Offline OP
Thanks Martyn
These look good. Will post when fitted
You wouldn't believe how thin the wiring going to the lights is.
I wouldn't use it for signal cabling!!!,
Matty #271067 29/04/15 06:48 AM
The urban cooling fan must take an input from the ECU as I understand it the fan kicks in below 10mph and if you are below 10mph the indicators stay on. Therefore both are speed sensitive and I would assume use the same ECU output.
By the way does anyone know what the black plastic box full of relays is for stuffed under the fuse box/ECU?
Matty #271915 02/05/15 12:32 PM
So that's the MOT Passed but with wheel Bearing advisories - but then again maybe there's supposed to be some play came the explanation -
Had to tighten the headlights too.
As for the knock on two ear spinners - from Morgan " it's down to the MOT testers discression" - Mmmmmm food for thought for another year anyway smile
Matty #271946 02/05/15 03:48 PM
AMC Offline
My M3W has just pasted her first MoT. I live over 100 miles from the nearest Morgan Agent so had to look for a more convenient provider. No problem, just go where the motor cyclist go; 16 miles.
Benfro Mog
AMC #272465 05/05/15 08:47 AM
My M3W has just passed its MOT, no advisories or issues with two-eared spinners or anything else. The MOT station are however used to Morgan's and thus are used to their foibles! happy3
Brian
2014 Morgan SP1 (Rocket Red)
Page 3 of 4 1 2 3 4
