9 members (Alistair, DJC, Colsmog, howard, meabh, Richardllll, lez, JD44, MartinB60), 280 guests, and 26 robots.
John V6 70
DaveW 67
+8Rich 66
9,208 Registered Users
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
Topics48,342
Posts813,007
RedThree
Page 1 of 4 1 2 3 4
#524266 25/07/18 06:31 PM
Hawki Offline OP
We returned from Italy a couple of weeks ago and parked the car in the garage. It had run perfectly for the holiday. When I tried to start it today for the first time it turns over ok but will not fire up.
The battery is fine as has been left on a trickle charger plus we tried a jump start to and just the same. There are no messages come up when I plug diagnostics in and the fuel seems to be getting to the engine bay ok.
Has anyone else had this issue? ANy ideas?
Hawki #524269 25/07/18 06:44 PM
Hm Not had that happen. I've had it where the immobiliser hasn't recognised the key a couple of times but that's cured by simply taking the key out and putting it back in but I don't think it even turns over in that instance.
Morgan Plus 4
Royal Enfield Classic 350
Brompton M6L
Giant TCX Advanced
Hawki #524270 25/07/18 06:44 PM
Immobiliser playing up?
'09 Gen2 MINI Cooper ragtop
Hawki #524273 25/07/18 07:10 PM
Oh no... I'm sure Krazy Horse will sort it. At least it didn't happen on holiday
Hawki #524278 25/07/18 08:05 PM
Has the immobiliser pellet fallen out of the key in the hot weather?
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 5
Hawki #524288 25/07/18 08:48 PM
fuel pump relay? happened to me a few weeks ago
Hawki #524298 25/07/18 09:35 PM
^^two good calls.
Hawki #524307 25/07/18 10:02 PM
Hi Hawki - I had a similar issue about 18 momths ago. It turned out that the cylinder head in the GDi has a separate earth lead located at the back of the head held by a 8mm bolt. In my case the bolt was very slightly loose sufficiently so to have a poor earth. As the coil packs etc are mounted on the head over the spark plugs a good earth for the head is required.
In my case this was sufficiently poor to cause a 'turning over but no firing' situation exactly as you describe. Simply tightening the bolt cured it immediately. Awkward to get to though.
+4 GDI Connaught Green, 2014
Magnolia
RichB #524308 25/07/18 10:06 PM
Good call lets hope that's the one as fuel is getting to the engine it seems.
2009 4/4 Henrietta
1993 Connaught Green +8 prev
Hawki #524310 25/07/18 10:07 PM
Something to check tomorrow......
Page 1 of 4 1 2 3 4
