1 members (Silverlady),
264
40
Topics48,341
Posts812,980
Posts: 697 Likes: 7
Posts: 697 Likes: 7 |
We returned from Italy a couple of weeks ago and parked the car in the garage. It had run perfectly for the holiday. When I tried to start it today for the first time it turns over ok but will not fire up.
The battery is fine as has been left on a trickle charger plus we tried a jump start to and just the same. There are no messages come up when I plug diagnostics in and the fuel seems to be getting to the engine bay ok.
Has anyone else had this issue? ANy ideas?
Posts: 1,543 Likes: 34
Posts: 1,543 Likes: 34 |
Hm Not had that happen. I've had it where the immobiliser hasn't recognised the key a couple of times but that's cured by simply taking the key out and putting it back in but I don't think it even turns over in that instance.
Morgan Plus 4 Royal Enfield Classic 350 Brompton M6L Giant TCX Advanced
Posts: 28,415 Likes: 177
Posts: 28,415 Likes: 177 |
Sold L44FOR 4/4 Giallo Fly '09 Gen2 MINI Cooper ragtop '90 LR 90 SW
Posts: 509 Likes: 1
Posts: 509 Likes: 1 |
Oh no... I'm sure Krazy Horse will sort it. At least it didn't happen on holiday
Posts: 5,221 Likes: 123
Posts: 5,221 Likes: 123 |
Has the immobiliser pellet fallen out of the key in the hot weather?
Posts: 196 |
fuel pump relay? happened to me a few weeks ago
Posts: 21,866 Likes: 167
Posts: 21,866 Likes: 167 |
Posts: 212 |
Hi Hawki - I had a similar issue about 18 momths ago. It turned out that the cylinder head in the GDi has a separate earth lead located at the back of the head held by a 8mm bolt. In my case the bolt was very slightly loose sufficiently so to have a poor earth. As the coil packs etc are mounted on the head over the spark plugs a good earth for the head is required.
In my case this was sufficiently poor to cause a 'turning over but no firing' situation exactly as you describe. Simply tightening the bolt cured it immediately. Awkward to get to though.
Richard +4 GDI Connaught Green, 2014 Magnolia
Posts: 35,774 Likes: 468
Posts: 35,774 Likes: 468 |
Good call lets hope that's the one as fuel is getting to the engine it seems.
Something to check tomorrow......
