0 members (), 280 guests, and 41 robots.
+8Rich 65
Adam12 62
John V6 59
9,215 Registered Users
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,365
Posts813,354
Members9,215
Rbt Aero8, Salmon, stevends
Page 3 of 9 1 2 3 4 5 6 7 8 9
Some good tips from you guys and I thank you all very much. The way my week is going it’s bound to be a pcb problem!
Originally Posted By Scrambledsignals
There is a common problem with the PCB that handles the dash electronics.
Seems that if you get water ingress then this can cause shorts on the PCB tracks that leaves the fog light permanently on.
The switches and relays are of good quality, but the PCB is not.
The PCB is manufactured by Zonefollow who I believe are no longer in business and when I tried to get a circuit diagram from Morgan they said they did not have one.
A replacement PCB is in the region of £600 but Morgan do not appear to have any stock.
If you do sort out the problem would be interested to know what the fault was.
The 4/4 of the original poster is still a current model....well it was until a couple of weeks ago. The PCB for that model is obviously still being manufactured. One for 3.0 Riadsters is another matter which is why my car has it covered in a plastic sheet 🙄.
I’ve had too many underdash leaks....now hopefully sorted.....and washer hoses pop off.
Anyone know the best way to gain enough access to the pcb to inspect/ remove it?
Take the dash off unplug all the cables, remove plastic splash guard/cover unscrew switch backs on pcb to release pcb from switches, don't forget to remove ribbon that goes to lamp panel. Pcb is double sided.
Mark - No Longer driving
With all the wisdom and experience exchanged in this dialogue I am now curious to know why, in respect of the original posting, a main dealer couldn't help? After all, it seems to be a relatively common problem. Don't want to start a drift onto a different topic though.
Rob T
2017 Tungsten Plus 4
Rog Offline
Unfortunately the older model but as I had a pic thought it might be of interest to somebody. As said I got away without repairing mine but I suspect the offending relay might be the Axicom IM 06 next to the switch.
PS –I believe that chip ‘enhancement’ is original scared
Roger
The 4/4 of the original poster is still a current model....well it was until a couple of weeks ago. The PCB for that model is obviously still being manufactured. .
Good, because that's exactly the problem I have, since we were caught in a down pour on the the way to TOTH a few weeks ago!!
If your dash is the same as my Roadster I have pictures of both sides if you need them, but if it's a failed diode you may not even see the failure.
Hi Johnbbank,
PM sent
Peter.
"Hasta la victoria siempre"
About 2 years ago my 2002 Plus8 had a similar issue. The rear fogs were intermittent often sending flashing signals to the car behind!
I worked through the circuit checking bulb,holder,fuses,wires, switch etc.
I narrowed it down to the control module behind the dash. A small black box.
I prised it open and the pub was loose, rattling round. I re glued it and the problem seemed cured. Not for long!
It came back. I tried Uncle Melvyn (February). Not in stock and factory order. GRRR.
MOT was due in November. Over the summer no progress in getting a replacement. Factory stock was for pre 1997 models and apparently not interchangeable. No news of any being ordered in.
So....choices were
Source one from Carbuildersolutions and sort out the wiring.
Replace with manual (might have been a MOT issue re cancelling)
Check the module.
I checked the module under a magnifier and saw two solder joints that looked iffy. I resoldered them and yippee! Problem solved and not returned.
Oh the joys of Morgan ownership!
Mind you solving it is a good feeling.
