13 members (itsfrank666, Burgundymog, B3MOG, OldSkrote, Barry13, davewhite, GrumpyPa, High Hamster, BrunswickGreen44, Alistair, Alverman, TBM, sbarracl), 362 guests, and 38 robots.
Adam12 69
+8Rich 67
John V6 59
9,215 Registered Users
SORN
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,367
Posts813,402
Members9,215
Rbt Aero8, Salmon, stevends
Thats interesting John, I didnt realise they worked individually. did you buy just one anti tramp bar, and what is the thinking behind fitting just one on the drivers side? Is it like prop walk in the marine environment? Intrigued 🤔
06 Saab 93
The 3 l cars had one, the 3.7 l I think 2. I asked at the time and that was the advice from Allon White who fitted it. The battery gets in the way on the passenger side.
It seems to work well.
2025 MG ZS EV aka Trigger
The S1 Roadster didn't get the anti tramp as standard, although the board was cut out ready on that side.
Fitted mine last week. Immediately on bumpy roads the steering was a lot calmer, but did feel a portion of that energy was transmitted into chassis instead , which you could feel. Overall an improvement though and only took an hour to fit.
Originally Posted by Robbie Mathisen
t the whole front of the car calmed down, in a way difficult to describe. It felt more stable, not moving around that much both horizontally and vertically (which I can't explain, but anyway - less "nodding dog"). It felt slightly closer to driving an ordinary car - in a good way. I admit that there might be a bit of placebo in this, and the changes were quite subtle. The only way I can explain this is that the BRS stiffens the whole front of the car, reducing the inherent flexing. And not only during braking, but most of the time, as I suspect there are constant micro-movements. Something that is needed? No, the earth did not move beneath my feet? Something I would recommend? Yes, for sure. A relativly small improvement, but cheap and easy to do. Next is the Panhard rod, lying on the garage floor ready to go in...
Fitted my SiFab Brake Reaction Bars today and agree with Robbie above.
The name Brake Reaction Bars is misleading as there is a big difference in the whole front end over bumpy roads and chassis flex in cornering with better steering feel in the corners. I found myself driving much faster over bumpy roads because the suspension now doesn't 'crash' over bad bumps.
I would say Brake Reaction Bars are probably the first modification you should do to a Morgan and I wish Id fitted them 18 months ago. Morgan should fit them as standard.
Rob
4/4 Sport Grey
I had brake reaction bars fitted about 1 month ago. The steering felt more direct after fitting particularly over bumps
Maybe I should refit mine and try again. I took them off as I didn't feel they made much difference to the narrow tyred 4/4.
I felt the Panhard rod did make a difference.
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
What a difference a change makes.. just recently fitted the Panhard rod to my 03+8, to complement the BRB/S, and also replaced the 17 yr old Sachs super touring rear dampers with Spax adjustable shocks (fronts were upgraded previously with the kingpins) ;I now feel confidently attached to the road at all times. Approval stamped by SWMBO "much better now its less bouncy" ………
Nice to meet up and have a chat Graham G4, hope the visitors are keeping you busy now the new Morgan Experience centre is open!
06 Saab 93
Fitted my SiFab Brake reaction Bars today and agree with Robbie above. The name Brake Reaction Bars is misleading as there is a big difference in the whole front end over bumpy roads and chassis flex in cornering with better steering feel in the corners. I found myself driving much faster over bumpy roads because the suspension now doesn't 'crash' over bad bumps.
I’m really glad they helped Rob
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Hi Simon
Thanks also for the fitting advise. I did grind a bit off the oiler bolt end of the bars to clear the wing stays but they were easier to fit than I thought.
I used a jack under the kingpin as you suggested and had no problem with the oiler bolt.
Matty at Lifes is fitting my Panhard Rod next week so I will report back on here!
Rob
4/4 Sport Grey
