0 members (), 138 guests, and 92 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
Logg Offline OP
My 1980 4/4 has a hard brake line that runs directly to the right side rear wheel cylinder, and then a second line that connects from the right to the left. I haven't seen such a roundabout connection before - and while I know the hydraulic fluid may not care (if it's bleed well) - I'd expect a brass T over the axle and separate runs to each side (with a bleeder on both side) might work better to get the air out of the system. Was this a previous owner getting creative when they lost parts, or was this an actual MMC setup for this car?
I can add a T and make up new lines to both sides, but I can't believe this was the factory set up. Thanks in advance...Logg.
John L
1980 Morgan 4/4
Southwest USA
Logg Offline OP
Should have mentioned there is a flex hose before the axle - it's not hard pipe from frame to axle as that would obviously cycle and fail. Should have been more precise with my words. Logg
John L
1980 Morgan 4/4
Southwest USA
Logg .... here's mine with T-piece ... during the resto, so all sat in place waiting to be connected up .... guessing yours has been PO modified!
TBM Offline
My .'72 is the same as above with a T piece, but in my vague collection of memories, I'm sure I've seen a set up like yours with a hard link pipe between rear cylinders. so it may be a factory fit.
I have seen early cars plumbed in with both methods from MMC.
The T-piece is a better system for bleeding , but both will work well, especially if you have a "power bleeder" .
If it worries you , then plumb in a T-piece , but if not continue to drive on your current system and make a note to convert it when you do a rebuild , or other major work.
Andy G
1999 +8 , Indigo Blue.
Logg Offline OP
Thanks to all for the info - I've never seen a series connection from cylinder to cylinder but can power bleed for now. A "T" and new lines over the axle go on the "list", but not at the very top. Logg
John L
1980 Morgan 4/4
Southwest USA
