0 members (),
138
92
Topics49,847
Posts837,389
Posts: 4 Likes: 1
Posts: 4 Likes: 1 |
My 1980 4/4 has a hard brake line that runs directly to the right side rear wheel cylinder, and then a second line that connects from the right to the left. I haven't seen such a roundabout connection before - and while I know the hydraulic fluid may not care (if it's bleed well) - I'd expect a brass T over the axle and separate runs to each side (with a bleeder on both side) might work better to get the air out of the system. Was this a previous owner getting creative when they lost parts, or was this an actual MMC setup for this car? I can add a T and make up new lines to both sides, but I can't believe this was the factory set up. Thanks in advance...Logg.
John L 1980 Morgan 4/4 Southwest USA
Posts: 4 Likes: 1
Posts: 4 Likes: 1 |
Should have mentioned there is a flex hose before the axle - it's not hard pipe from frame to axle as that would obviously cycle and fail. Should have been more precise with my words. Logg
Posts: 5,586 Likes: 603
Posts: 5,586 Likes: 603 |
Logg .... here's mine with T-piece ... during the resto, so all sat in place waiting to be connected up .... guessing yours has been PO modified! ![[Linked Image]](https://www.tm-img.com/images/2023/06/24/Screenshot_20230624_003932_Gallery.jpeg) K
Posts: 6,667 Likes: 433
Posts: 6,667 Likes: 433 |
My .'72 is the same as above with a T piece, but in my vague collection of memories, I'm sure I've seen a set up like yours with a hard link pipe between rear cylinders. so it may be a factory fit.
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
I have seen early cars plumbed in with both methods from MMC.
The T-piece is a better system for bleeding , but both will work well, especially if you have a "power bleeder" .
If it worries you , then plumb in a T-piece , but if not continue to drive on your current system and make a note to convert it when you do a rebuild , or other major work.
Posts: 4 Likes: 1
Posts: 4 Likes: 1 |
Thanks to all for the info - I've never seen a series connection from cylinder to cylinder but can power bleed for now. A "T" and new lines over the axle go on the "list", but not at the very top. Logg
