6 members (MartinB60, Luddite, Rex_tulips, DCH, RJW, Bunny), 334 guests, and 12 robots.
+8Rich 65
Adam12 62
John V6 59
9,215 Registered Users
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,365
Posts813,360
Members9,215
Rbt Aero8, Salmon, stevends
Hi all, would appreciate any help or experience on a small coolant leak I'm seeing on my 1990 +8. Seems to be coming from the connections to the 2 tubes in the 'V' of the engine? Can't really get in and see anything but no drips from the heater connections, these are dry, so can the tubes develop holes or likely to be the water pump end that you cannot really get at? I'm not at the stage of lifting off the plenum / inlet manifold to get better access - what is the way to get better access to see what actually leaking? Topping up the expansion tank every 100 miles as seems to run dry - guess the coolant get sucked back into the system once it cools down? Appreciate thoughts and experience of similar issues. Many thanks
I am not sure if there is an air vent within the filler cap or pressure relief valve but if that's defective the coolant pressure may be excessive.
Double check no coolant is finding its way into the engine oil because if it is, there is a risk of engine damage by contamination. Do an oil change to be on the safe side. !!
Graham
1.8 4/4 Ivory.
Toyota Yarris
Volvo V70 (D5 replaced by D4)
https://moggo-blog.blogspot.com/
1 member likes this: jeremylparker
Quite common on rv8 engine to have a slight coolant leak into the V. First thing to check is the tightness of the jubilee clips at each end. There’s a pipe running under the inlet manifold with short rubber connectors at each end and over time the start to weep. Easy fix if it works.
