SORN
New
Topics48,375
Posts813,508
Members9,215
Posts: 26,766 Likes: 427
Posts: 26,766 Likes: 427 |
Makes no difference. But the exhaust pops and bangs .
Posts: 42 Likes: 5
Posts: 42 Likes: 5 |
What fuel do you use? Try 99 octane fuel (if you've not done so already), but even so, modern engines should allow for using 95 without pinking.
Morgan Plus Four Metallic Emerald Green and Pebble Biscuit, 'clutchless'
It is running on Esso E5 which is ethanol free
Posts: 7,914 Likes: 243
Posts: 7,914 Likes: 243 |
It is running on Esso E5 which is ethanol free Unfortunately I don't think Esso is 'E' free now, however your BMW engine is tolerant of ethanol to levels way over UK uses and will map the ECU automatically
Exactly. I don't think it can be old fuel after 1600 miles
Posts: 240 Likes: 4
Posts: 240 Likes: 4 |
Throw some supper plus in it - the higher octane widens the knock window so it should stop it if it is pinking. There are knock sensors which should stop it but give that a go
Posts: 28,432 Likes: 182
Posts: 28,432 Likes: 182 |
Esso E5 is the higher octane fuel (98 RON IIRC), sadly not been ethanol free since last September or October. Tesco 99 is not recommended - caused Peter Jenks all sorts of problems with his Aero +8.
Sold L44FOR 4/4 Giallo Fly '09 Gen2 MINI Cooper ragtop '90 LR 90 SW
Cheap supermarket (Tesco) fuel was not liked by my S1 Roadster. It caused lambda sender problems on the passenger side in winter. Swapping to Shell solved it.
Posts: 9,285 Likes: 69
Posts: 9,285 Likes: 69 |
My Plus8 with Gems management ran better on V-Power higher octane. The management light came on occasionally using std 95 octane. Checked everything but no joy. Started using the V-Power and it stopped. The Plus Four runs on either E5 or E10. No really obvious difference in performance but slightly better mpg with E10. As happened too with the Plus8. The Plus Four just had it's first annual service on Friday with 7k miles done. Two extras sorted. Loose grill and rear clunk at low speed stop-start.The graphite grease spline lube looks to have worked. Long winded crawl home on the M4 with a lot of stop-start and no clunk.
Correction. Slightly better mpg with E5 petrol.
