6 members (TeddyAds, deano, Mogdavid, MATTMOG, Bunny, Mark+4), 298 guests, and 82 robots.
Topics49,849
Posts837,415
DazMog, The Impaler, tlchzj79
Page 2 of 9 1 2 3 4 5 6 7 8 9
John V6 #804393 26/07/24 10:02 PM
John V6 Offline OP
Makes no difference. But the exhaust pops and bangs .
John V6 #804437 27/07/24 06:36 PM
What fuel do you use? Try 99 octane fuel (if you've not done so already), but even so, modern engines should allow for using 95 without pinking.
Morgan Plus Four
Metallic Emerald Green and Pebble Biscuit, 'clutchless'
One of the last MY22
John V6 #804439 27/07/24 07:27 PM
John V6 Offline OP
It is running on Esso E5 which is ethanol free
John V6 #804440 27/07/24 07:33 PM
Unfortunately I don't think Esso is 'E' free now, however your BMW engine is tolerant of ethanol to levels way over UK uses and will map the ECU automatically
John V6 #804441 27/07/24 07:42 PM
John V6 Offline OP
Exactly. I don't think it can be old fuel after 1600 miles
John V6 #804442 27/07/24 08:11 PM
Throw some supper plus in it - the higher octane widens the knock window so it should stop it if it is pinking. There are knock sensors which should stop it but give that a go
John V6 #804449 28/07/24 04:57 AM
Esso E5 is the higher octane fuel (98 RON IIRC), sadly not been ethanol free since last September or October. Tesco 99 is not recommended - caused Peter Jenks all sorts of problems with his Aero +8.
John V6 #804453 28/07/24 07:10 AM
John V6 Offline OP
Cheap supermarket (Tesco) fuel was not liked by my S1 Roadster. It caused lambda sender problems on the passenger side in winter.
Swapping to Shell solved it.
John V6 #804513 28/07/24 07:03 PM
My Plus8 with Gems management ran better on V-Power higher octane. The management light came on occasionally using std 95 octane. Checked everything but no joy. Started using the V-Power and it stopped.
The Plus Four runs on either E5 or E10. No really obvious difference in performance but slightly better mpg with E10. As happened too with the Plus8.
The Plus Four just had it's first annual service on Friday with 7k miles done. Two extras sorted. Loose grill and rear clunk at low speed stop-start.The graphite grease spline lube looks to have worked. Long winded crawl home on the M4 with a lot of stop-start and no clunk.
John V6 #804548 29/07/24 08:51 AM
Correction. Slightly better mpg with E5 petrol.
